Visitor Agreement.
How can a tiny company like AMSOIL bring up a ATF that satisfies all the big requirements of Dexron/Mercon/F type/Chrysler ?
Sounds fishy?
Anything to watch out if I were to use it in a Auto Tranny that calls for DexronIII/Mercon?
Toyota Camry originally switched at 25,000, now 143,000 changed about every 30,000
Chev Corsica, changed at 49,000 (when acquired) then every 30,000 accident killed it at 128,000
Mercury Mystique changed at 30,000, now at 67,000
Isuzu Rodeo, changed at 57,000 (when acquired) now at 73,000.
Nissan Maxima switched around 30,000 sold at 60,000 no problem.
The only manufacturer I have not used this on is Chrysler. It is definitely a replacement for Dexron III and Mercon V they saly also Chrysler + 3 or 4 but I have not tired it in a Chrysler.
It is not a replacement for Ford Type F. I would not use it for Type F older Ford Trannies and some Ford PS units still use the Type F, my Mystique even though the tranny fluid is Mercon V.
Stuff does work!
I also have switched to Mobil One synthetic ATF. Not only is it a superior lubricant to normal ATF, but I seemed to have gained a little more mpg (1) and also the shifting is way smoother.
What is that supposed to mean?
Is AMSOIL ATF 100% fully synthetic or does it have catches like Mobil 1?
To Armtdm, did u notice any changes in shift quality, especially when cold at 20F or so?
Was it better shifting(quick,precise) as compared to regular ATF?
As to gear oil though, there I have noticed a significant diffenrence with the ease of shifting and soothness of synthetic.
The only reason I mention this is...it has been suggested on this site that "an equivalent 5-30 synthetic" would also do for all those Supercharger, dirty oil changes that need to be done...(even though GM tells you not to)
So..... all you Amsoil, Redline, Mobile 1, Shaeffers, and other Oilwizards out there, 'got any ideas?
That P/S fluid gets filthy, and full of metal debris worse than your engine ever will. (the P/S systems have no filters,nor does the supercharger) I feel like' the voice in the wilderness, but I am trying to be heard on this subject...stop losing sleep over obscure technical details of each particular brand of motor oil, wake up and realize that there are expensive, high stress, neglected wear items needing oil changes as well as your pampered motor that gets regular, state of the art, synthetic lubes, plus, the benefits of coolers and filters..The power steering units, superchargers and automatic transmissions all need love too.
Their web address for the required page is rediculously long and won't fit here.
http://www.briggsandstratton.com
My power steering pump is under so many lines and buried so deep at the back of the Buick engine compartment, that unless you have a map, you can't even find the damn thing.
Using the 'suck it up' system, I was able to deal with another of GMs' Stupid Engineer Tricks'
I know the dino Super Tech is supposedly Quaker State, but I haven't heard any theories re: ST synth being QS also.
2002 Denali XL. Oil plug is magnetized and had 1/8" metal shavings. Engine has 66.4 hours.
In a related case, a friend of mine just toured a major window factory and the people there said the windows they make for Home Depot are of lesser quality than their "standard" line. So, you feel good buying a name brand, but in fact, you are getting a lesser quality product.
P.S. - I have no proof if any of this is the truth!
If you like Quaker State, why buy the Super Tech that may or may not be as good as the real deal? If you can't afford the extra $3-5 (every 3 or more months) maybe your living over your means!
Of course this is assuming you like your car, have owned it from new (or close), and want it to run for ever.
Same thing with oil. Unlike vegetables, which in nature come in a variety of qualities, and can be sorted, it would be easiest for the supplier to simply buy the oil rather than to demand a lesser quality. After all, most of the cost in oil is in marketing and distribution channels, not the cost of individual additives.
I quote from the Blackstone Labs oil analysis site:
http://www.blackstone-labs.com/which_oil_to_use.html
"You can go into any mass retailer (Wal-Mart, K-Mart, Meijer, etc.) that sells engine oil and buy a 10W/30 (or any other preferred grade) that will perform well in your engine. We don't know of any major retail chains selling their own oil brands that actually produce those products. They are quality oils produced by major oil companies. The only difference between these private labeled products and the major company brands is the container, and about 50¢ a quart.
But wait! We do actually have a preference when it comes to buying oils for our personal use engines. That preference however, has little to do with brand names."
Same thing with gasoline. In the St. Louis area QuikTrip dominates gasoline retailling and can control prices. Yet they own no refineries. I've had some people say they would not buy QT, only "major brands" like Amoco. Guess what, with the closing of one of the two area refineries, almost all gas in the St. Louis metro region is going to be Shell. People who insist on "major" brands may be steered to an independent dealer who might find it easier to cheat on what he was actually putting in his storage tank. You can bet QT, controlling their outlet isn't going to take that chance.
Same with oil. Several years ago I saw an expose on an autoparts retailler which was selling "black market" oil with name brands that didn't even have any detergent in it. Wal-Mart's not going to take that chance. I'm not a huge believer in Quaker State, and I think it's entirely likely that Wal-Mart might switch its contracts to Valvoline in the future if they could save three cents a quart. On the otherhand Quaker State has merged with Pennzoil and will shortly merge again, so brand loyalty, as such means little IMHO.
Especially with the ever-changing oil company climate due to mergers and acquisitions, it's very difficult to "buy what you know is good" because it's darn-near impossible to know what is good to any degree of certainty.
3 months ago I was telling people on the Isuzu Trooper and Kia Sedona boards that synthetic blend oil is a waste of money and, to me, major-brand full synthetic was worth the extra cost. In the past 3 months, I have totally changed my tune based on what I've read on the oil-related Edmunds boards.
I have no idea what's good and what isn't, even though I would really like to know. At best, I'm making an educated guess.
Perhaps the greatest utility of the rating systems is that it makes the product a commodity. Marketing likes to make the product being marketed to stand out. So I think that given the standards, you really don't have a lot to worry about. In fact you can buy on price or even because you like the color on the container, Wally Marts house brand, or even as stupid as "DUNG BEETLE JUICE". (Again, given the standard)
1/8" metal shavings don't sound encouraging. That is rare (at least for me), and I drive good ol' American steel. It stands to reason that if that continues then you have a problem.
Claude in Tillsonburg, Ontario
Yes they do. And so do petrol-based oils.
Testimonials such as yours are helpful, and I enjoy reading them. But to quote one of my favorite statements from Psychology 101:
"Correlation is not causation."
I don't know why they would want to run 5W20 with the Trooper anyway, since Isuzu does not specify/require 5W20.
In Canada in February that Dino crap does not even pour at 20 below Zero. I'll stick with Mobil 1 or a top synthetic until somebody proves me wrong. My lexus LS 400 has it and my Camaro Z-28 that has been stored for 4 months has it. By the way just started it today after sleeping for 4 months and it started like it had been parked yesterday. Why?? Synthetics certainly helped as the oil pressure came up instantly. My old 5.0liter mustang use to achingly get to its proper oil pressure when I had Dino oil in it. Once I switched to Mobil1, BAM the oil Pressure came right up when cold.
YES, I have lots of correlation and experience with 4-5 cars with synthetics and my causation says stick with synthetics!!!
Claude in Tillsonburg.
This certainly strengthens your claim. And your claim may well be 100% true. I have nothing to disprove it. In fact, I am inclined to agree with you. All I was trying to point out is people should not think that something very general ('synthetics are better') is 100% true based only on individual experiences.
Especially for your cold-weather circumstances, synthetic seems to make good sense.
However, the discussion here has led me to believe that the differences between the current oils sold as "synthetics" and the "conventional" SL-rated oils are narrower than ever before. My personal conclusion has been that I will stop using Mobil 1 when my supply runs out and I will instead use one of the major-brand SL-rated petrol-based oil that contains hydrocracked base stocks.
another one, has a dodge 4cyl van, excess 450,000 miles. he too, a blend.
anyway, i have some valuable points to bring but need to get back to work. I will post later,
have a good day.
bob
Re: the article you posted:
"the new specification, ILSAC GF-4, will demand that oils go easier on emission system catalysts..."
I sincerely hope this is the case. The catalytic converters on my 95 Ford Contour were just replaced, for the second time, and the car has only 71,000 miles. This seems to be a very common problem on the Contour. How a set of cats could be good for only 30-40k miles is beyond my comprehension. At least my major emissions warranty is 8 years/80,000 miles, so the car was covered both times.
Perhaps failure to heat the engine up every time you start it.?????
i've got to get a picture posted before i go on with the synth and protection issue i plan on discussing. hopefully i will have it done before the week end.
Reply:We are an independent laboratory not affiliated with any oil company, refinery, manufacturer, or distributor.
We sell no product.
We provide a service, oil analysis, to private individuals, industries, truck fleets, and aircraft owners.
We publish no opinions on any types or brands of oils.
Thank you for your interest -
Sue Stark
Blackstone Laboratories
That may have happened regularly with the previous owner, as they put few miles on the car. However, they had the cats changed at 40k miles, then I bought the car at 50k. By 70k the car was not really drivable due to almost no power and rough running.
My trip to work is 15 miles one way, with 5 miles of freeway around 75mph. So since I bought the car, I'm usually getting the engine to a pretty good operating temperature, I think.
