Synthetic motor oil
16364666869175
  • mdecampsmdecamps Member Posts: 115
    I was at Walmart today and found a bottle of the new "SuperSyn" 10W30. The numbers are not impressive. Here is a comparison between SuperSyn and TriSynthetic 10W30:
    TriSyn: Flashpoint 470F
    Pourability: -65F
    Supersyn: Flashpoint 400F
    Pourability: -49F
    It appears to be severely degraded.
  • knapp3knapp3 Member Posts: 112
    You're right. I did expose my hand on another post. It is Motorcraft oil. Comparable data about Ford's oil was difficult to find. Other manufacturer's product date was more readily available. I stumbled on it accidently at this site:
    http://www.motorcraft.com/standard.asp?T=2&M=44&PageID=74
    Lord knows there is a lot to evaluate. But of all the data points to compare, I wanted to see what you guys thought were the most important. I tend to zero in on flash & pour points, and the viscocity index.
    Mdecamps...I noticed the same Supersyn reference to 400F on the bottle, and that figure is also mentioned in the text of the product data sheet. But, the product data sheet also claims that the Flash Point ranges from 450 to 491F depending on oil weight. What am I missing?
  • loubapacheloubapache Member Posts: 30
    I have updated my compilation (comparing the Tri-Synthetic with the new one with SuperSyn). See it at
    http://members.net-port.com/~loub/car/oil_S.htm
    Or go to the Mobil 1' site at
    http://mobil1.com/supersyn/index.jsp
    The specs of the new oils with SuperSyn are exactly the same as the SL rated Mobil 1 Tri-Synthetic (which lived for about a month from mid-March to its replacement by the "with SuperSyn").
  • jimi2jimi2 Member Posts: 2
    Does anyone know what company manufactures Synthetic/Synthetic Blend motor oil for Walmart? Do you thing it's any good?
  • pepper50pepper50 Member Posts: 195
    My GMC crankcase holds 7 quarts oil. I've considered switching to synthetic, then I heard a fellow say he mixes Mobil 1 and dino oil. With this many quarts to deal with, would that be a reasonable approach? If so, how many quarts of synthetic to dino? Do any of you mix your oils like that? I'd probably still change it every 3-4,000 miles or so. That's why it would get expensive with 7 qt. of Mobil 1. Thanks for comments.
  • fleetwoodsimcafleetwoodsimca Member Posts: 1,518
    I have read in this thread on several occasions that Walmart synthetic oil is provided by Quaker State. I have never checked that out, myself.
  • adc100adc100 Member Posts: 1,521
    I'm sure the only thing that lasted a month was the SL containers. I'm sure "SuperSyn" has already been added. They don't make major changes their formula very often It takes them 2 to 3 years to test their product. You can bet that the forth coming specs on zinc will decrease with the next round of API changes. Mobil will probably be pushing hard for that now that they apparently have a better wear package. I'm guessing that their zinc content is way down. Thanks for the info. Since I'm a registered user on the on the Mobil 1 board they were supposed to email me on Monday with the info. Loooks like they jumped the gun. BTW I believe they screwed up the Kinematic Viscosity numbers and got them in the wrong columns. They make mistakes like that all the time on their website. They neeed to cut off some heads.
    pepper50Syns basically give you longer drain intervals and protection under off normal conditions. So 1 quart would be better than no quarts but not as good as 2 quarts etc. In this case you truly get what you pay for. I think discussion on this board has indicated that blends are 10 to 25 percent syn(???). Probably now with the new SL standard-blends are a waste of money-but who knows.
    Later,
    Al
    No, they did not. All numbers are correct on the new with SuperSyn site.
    When they released the SL Tri-Synthetic specs, they screwed up the kinematic viscosities. But they have pullled the plug on that site.
    How can you trust them not making this kind of mistakes in their oil? "Woops, I put all mineral oil in this SuperSyn batch."
    They talked about how good the low temperature performance is of the new with SuperSyn. But the fact of matter is that the 10W30 with SuperSyn has a pour point that is 15 deg F higher (-49 deg F in SuperSyn vs. -65 deg F in Tri-Synthetic) than that of the Tri-Synthetic.
    They also talked about how good the high temperature performance is of the new with SuperSyn. But the fact of matter is that the 10W30 with SuperSyn has a flash point that is 15 deg F lower (455 deg F in Supersyn vs. 470 deg F in Tri-Synthetic) than that of the Tri-Synthetic.
    To meet the tough Eurp specs, the pour point of the 0W-30 and 0W-40 did not increase (suggesting the same amount of PAO in the base stock mix).
    I am done with Mobil 1.
    Anybody interested in buying four 5-qt jugs of Mobil 1 Tri-Synthetic 10W-30? Pick-up only please (I am in Western Michigan) or I can deliver to Grand Rapids, MI. The price is $17.88 plus 6% tax so it is $18.95 per jug (that is what I paid at Wal-Mart on 3/3/02).
    I believe the improvement is in the anti-wear catagory so I'm not very concerned about the minor differences in the upper and lower end. The other key point is that its still 100% syn.
    If I could find objective information out there that some other oil can outperform Mobil 1, I'll switch. But right now there simply isn't any. No other company publishes their results in the SAE to the extent that Mobil does. For me that's the best place to determine what the oil can do.
    Can you tell me if there is any objective information with documented-non advertising test data out there indicating that another product can do 15K oil changes with almost no engine wear after 200K??
    Al
  • brennekebrenneke Member Posts: 43
    Below is a blurb that I took off the SuperSyn site. What I really have to wonder about is what they are saying about "less impurities". Is this just the mistake of a marketing guy or are they telling us that their latest oil contains alot of highly refined mineral oil? The 400 deg. spec. is a mistake right?
    Mobil 1 with SuperSyn&#153; protects engines up to 204° C (400° F). It contains less impurities, so it protects better than conventional oils in cold weather (as shown by the pumpability limits indicated in the table below). This means that Mobil 1 with SuperSyn&#153; provides outstanding protection against wear at start-up, when most engine wear occurs.
  • bobistheoilguybobistheoilguy Member Posts: 270
    finding the new mobil and while I was at it I found a non api high milage penzoil oil that recently came out.
    Of course I went straight to my shop, pulled the machine out and went to work.
    One person emailed me and said "Timken & Falex tests can be and often are manipulated by operator of machine, you can get a better "PULL"
    using baby oil then Schaeffer's Best Oil by manipulation of machines"
    In response to this, On this machine, you can make some oils appear not to be working when in fact they will plate up. You cannot make a lube plate up if it doesn't have some barrier properties. I have tried that with water, pb blaster, wd 40, schaeffers 131 fuel additive and many more things.
    I have been using this for quite some time and know how to show what I want as long as it has some barrier properties. THIS IS NOT DOING ME ANY GOOD to try and fool myself is not practicle. Thats kind of like cheating on a test. My main purpose is not to fool myself but to examine the actual shear protection that these can produce. Alot of oils produce small amounts of resistance to shear and with a very little pressure will tear through the small amount of barrier present.
    So, now that is addressed,
    I took the new and improved mobil with all the great marketing info on their bottle about better protection and such and on a fresh bearing, applied minor amounts of pressure to allow any kind of barrier lube additives to bond up with the friciton/heat produced. In every instance, no matter what I did to get it to plate on the bearing, I could not get it to do it at all. No matter what i did.
    The penzoil high milage oil produced a min amount of resistance but did not impress me to have much since it sheared out very easly.
    MaxLife from valvoline.. I put it in, applied the same way as the other two prev oils, it went to plating up. the longer i run it the harder it became to break through. This oil has a much better protection against shearing than most all other conventional oils I have come across.
    Having not run maxlife in an engine, i have not seen how it holds up under real world conditions, but given a choice between those 3, mobil is the only one api certified where as this penzoil and maxlife isn't.
    For wear protection, maxlife hands down is my choice between the 3 and i would then run for a 3k test and see how it holds up in other aspects using oil analysis, and if doing well, would extend my drains in 2k increments until i saw it starting to increase in oxidation levels.
    I returned a 5-quart jug to Wal-Mart a couple weeks ago, after deciding to go with a well-regarded SL oil instead of paying extra for synthetic. The clerk didn't even ask any questions about the return. As long as you have your receipt (even if you don't?) you should be fine.
    Saw 3 weights of Amsoil at my local Murray's Discount Auto Parts yesterday. 0W30 was $8.99/qt. 5W30 and 10W30 were $6.99/qt.
    I'm not sure which 'series' each of these are. The 5W and 10W both said 'exceeds SL blah blah blah' but I don't remember if the 0W said the same. The 0W bottle had slightly different wording on it.
    Just wanted to mention this since I didn't think any major chain stores carried Amsoil.
    Murray's is running the special that seems to come up every spring. Buy 6 qts Mobil 1, get a free Mobil 1 filter. Murray's price on Mobil 1 isn't the greatest - $4.69 in my area. And my store didn't have the new SuperSyn formula yet.
    I can get a case of Mobil 1 for $21.99 at Sam's Club. Comparing that with the Murray's price, it's like paying $21.99 for the oil at Murray's and getting the filter for about 6 bucks. Not too bad.
    Current evidence has caused me to pick up a bottle of STP off a shelf, and read the label a bit. As a kid, I used the stuff in my small displacement motorcycles-- and it helped immensely to improve compression (ring and cylinder wear). I am considering using it again, and this time to get some MoS2 on my babbit...
    Comments? Do you see any pitfalls?
    Auto engine, or lawnmower engine?
    What's MoS2?
    I've been intrigued a bit about STP lately too but can't remember why. Was the consensus that STP may actually help to reduce wear, making up for that deficiency in many/most brands of today's motor oils?
    I'd be careful of straight mos2. you can get mos2 in a solid form like ptfe, will seperate from the liquid that is holding it. you want to make sure it is a soluble moly not one that settles out.
    schaeffers 132 is a soluble moly.
    to those of you who have tried to find any of the schaeffers reps with no avail, i just found one in ark that said he will ship any quanities to where ever. I in no way get anything from this and is his deal only. And I am only posting this because I have recieved requests from some about how to obtain these products.
    just email me and i'll supply you with his info if you need or want the connection.
    Here are a couple of interesting notes:
    First, the pour point and the flash point of the new SuperSyn 15W50 is actually improved over the Tri-synthetic. The 10W30 is the one that showed the greatest degradation....they also mention that it is specifically for higher mileage engines. Mobil states several times on their website that this is the "best Mobil 1 oil ever"
    Does anyone have any idea what this new anti-wear package is? I'm guessing that the zinc is down, but what have they used to increase the wear protection? That seems to be their main selling point now.
    Mark
    I personally believe it is like some of these others with myster additive packages like synerlec and such. So far, I'm not impressed by anything more than their advertising campain. Almost as good as amsoils. Atleast amsoil does have higher levels of anti wear. mobil's showed none in my little test. That is as far as I will go in an oil that does that. It acts more like some food grade products that i have tested with much of nothing for wear protection.
    How about using STP in order to gain Molybdenum disulfide (MoS2 "moly")? Surely, and especially in view of the successful years of availability, it would be an excellent addition to most any oil for the majority of us. Can you site negatives against STP? Is it not as good as your Schaeffer's similar product?
    bluedevils :: I was thinking in terms of using it in most any internal combustion engine-- cars, trucks, implements, motorcycles, etc. I am rather convinced that gaining moly is a worthwhile goal, now that most oils are relatively deficient in barrier protection.
    I do know the use the higher levels of zddp not mos2, which by reports from the lubrication industry claim to have a negative effect on the cat's. That being said stp has no moly but is heavly loaded with zddp. As for the thickness of it, I don't know if that is a bright stock or what., the 132 has a VI additive and is the only one i have seen that uses a soluble moly. there is some moly additives out there one of which actually turns the oil black. That is common here in jiffy lube. I haven't checked it but suspect it would have to be shaken before poured which is a no no when talking additives. this idicates the additive will seperate and is not suspended.
    here is a copy of the tech data i have on the 132..
    #132 MOLY E.P. OIL TREATMENT
    Moly E.P. Oil Treatment is a highly fortified extreme pressure engine oil treatment.
    Moly E.P. Oil Treatment contains a highly specialized additive package. When used at the recommended treatment rate, this additive package allows Moly E.P. Oil Treatment to provide the following performance benefits:
    1. Increased compression through better ring seal.
    2. A reduction in oil consumption.
    3. Elimination of sticking valves and lifters.
    4. Reduced blow-by.
    5. Increased oil pressure.
    6. A reduction in engine friction and wear.
    7. Increased power.
    8. Better viscosity control.
    9. Extreme pressure protection of the engine bearings, valve train, and pistons and piston rings.
    To complement this highly specialized additive package a proven frictional modifier, Micron Moly® is further blended into Moly E.P. Oil Treatment. Micron Moly® is a liquid soluble type of moly that plates to the metal surfaces of the engine. Once plated, the moly forms a long lasting lubricant film in which prevents the metal surfaces from coming into contact with each other. By preventing metal to metal contact, damaging frictional wear is eliminated, which leads to less downtime and longer equipment life.
    TREATMENT LEVEL
    One pint of #132 Moly E.P. Oil Treatment to every 5 quarts of engine oil.
    TYPICAL PROPERTIES
    API Gravity 60°F (ASTM D-287)
    Specific Gravity
    Flash Point °F/°C (ASTM D-92)
    Fire Point °F/°C (ASTM D-92) 29.2
    .88
    475°/246°
    510°/265.5°
    What is this stuff? Who makes it? Under what brand is it marketed/sold?
  • longo32longo32 Member Posts: 81
    Want to thank Bobstheoilyguy for getting all that new Mobile Syn into the discussion. Sounds like a high priced Dud, to me.
    What I found in scrounging around the Net' after his reference to the Valvoline Maxlife, was some very good info on the Lube, and then I ran into 'Shootout at the Amsoil Corral!
    http://www.1st-in-synthetics.com/valvoline_maxlife.htm
    Amsoil must be worried about losing some market share to the new kid in town, to go to this much trouble. The Valvoline is not touted as a full synthetic, or if I'm not mistaken, not a Synthetic at all, and IMHO Amsoil should start publishing some independent tests against the other Synthetic Bullies in the marketplace.
    Sure, the Valvoline took a few cheap shots, but how many people need an 10-30 oil that has a pour point of more than -39....I live in the "home of 5 Stanley Cups" and I don't. And common'
    Amsoil, the Valvoline only costs $1.99 a Qt! Pick on somebody your own size!
    I dropped an email to STP, and will report here what they say about MoS2 in their OIL TREATMENT product. STP = Scientifically Treated Petroleum, by the way!
    I think that the Mobil 1 deal you mentioned is pretty good. Especially if its the SuperSyn. I'll have to check on it.
    I still would not consider the STP and take the chance on either screwing up the additive package or the CarConverter. You really don't need any more protection.
    Sometimes reasoned thought gets us in trouble, but it does seem reasonable to assume that STP is not a problem for catalytic converters, or for existing additive packages in current mass market oils. STP has been around nearly forever, and I am unaware of any storm clouds in their history. I am interested in barrier protection, and continuing to pass the state emissions test every two years, as well. Have you heard any reports of regrets from using STP, other than spending the money?
  • ocelot1ocelot1 Member Posts: 101
    Acording to thoses test numbers above I'll stick with the maxlife its so close on all those test. 13deg on flash point,you think those last 13deg will make a difference? .020 difference on the wear test, and 3.5% on the noack volitility. These numbers are so far at the end of the spectrom that 2.14 a quart Verse 4.99/5.99/6.99 a quart seems an easy pick for me.Tony
    I have not seen nor heard of anyone with relations to problems and stp. Of course havoline, shell, quaker state, premere,amalie, mobil,and all have been around a long time as well most if not all have no storm clouds, but yet they have reduced the zddp levels.
    I personally don't know how much truth there is to the cat contamination theory. In some instances I kinda feel like it's the 70's gas crunch conspericy all over again, hey no gas, price goes up then now that's not a gas problem but gas prices stay up. here we are again, hey cat burning out, lower antiwear addtives, now car engines won't last as long, thus allowing more engine/car sales to increase. Toyota just happen to be the first to experience the problems to engines due to this lowering antiwear effect.(no i don't buy into all of these people not doing proper drain intervals. I know some are but that many? think not. anyway, another story perhaps)
    Anyway just things that go through my warped little mind at times. no proof of that, but sometimes i fall of the wagon at start left winging it.LOL
  • brorjacebrorjace Member Posts: 588
    On Friday, I stopped by a walmart and saw some Mobil 1 "SuperSyn" (15W50, I think) and looked the bottle over. I wasn't looking for pour/flash points but I just wanted to read the marketing hype.
    One thing struck me as absolutley hilarious. It talks about Mobil 1 being used by Roger Penske ... and then in the bullet points it says "sutiable for amateur racing".
    Um, what's wrong with this picture? Why isn't it suitable for professional racing? Isn't that what they want us to believe, that the Mobil 1 in all the race cars is the same stuff that's in the bottles on store shelves? And, hey, isn't Roger Penske a professional in the racing world???
    Who do these people think they are fooling!?
    Thanks Bob, for the info on Max-Life. My buddy switched all of his cars from various dino oil and synthetics over to this stuff and he'll be happy to hear about your Timken results.
    I don't think there is a HUGE downside to using STP in newer cars ... but it is a polymer (I have always been told) and is subject to shearing down, forming sludge and/or boiling off. As long as you don't go too long between changes, it shouldn't be a problem.
    As for catayltic converters, I heard that they will be made increasing cheaper (fewer preciuos metals in them) from now on ...
    --- Bror Jace
    Mobil is not going to fool you or me but it can still fool 95% of the oil consumers.
    We have so many people just blindly trusting Mobil 1 oils regardless.
    Mobil Delvac 1 is an excellent oil. That does not automatically mean Mobil 1 is an excellent oil.
    As a matter of fact, I believe Mobil1 0W-40 and 15W-50 are excellent oils. But the 5W-30 and the 10W-30 are not excellent oils, IMHO. However, 5W-30 and 10-W-30 are the one bring Mobil $$$ in the US.
  • charlesb_lacharlesb_la Member Posts: 37
    From Mobil's website...
    http://mobil1.com/products/faq.jsp?catId=19#faq5
    Q. Red Line Oil talks about "four-ball wear," "load wear," "Falex wear" and "Timken psi load" for their synthetic oil. Are these valid tests?
    A. These tests are low-cost tests generally used to determine the performance properties of grease. They do not correlate with engine performance tests. For example, the use of an additive such as lead naphthenate would yield excellent results in these bench (or lab) tests, but would cause excessive oxidation of an oil in an engine and would cause a motor oil to fail the industry standard oxidation test known as the Sequence III test.
    None of the tests referenced are used by API in determining gasoline engine motor oil performance (SL is the current, most severe oil classification), nor are they used by engine manufacturers. The API approval requires the following tests:
    L-38 for bearing corrosion.
    Sequence IIIF for oxidation, deposits and wear.
    Sequence VG for sludge, wear and varnish.
    Sequence II for rust.
    This slate of tests can cost over $75,000 to run &#150; considerably more than the simple bench tests mentioned.
  • chikoochikoo Member Posts: 3,008
    I had changed oil in my '90 ford taurus last month at a local service station. He used regular dino oil(dunno the make) for the change.
    After 1000 miles, the dipstick showed dark brown oil and down by 1/2 a quart.
    I had a bottle of 5w-30 AMSOIL with me and just threw in 1/2 a quart of it in the crankcase.
    I checked the dipstick again...and what do I see?
    The color of the oil had changed to near colorless. just like when u change the oil.
    I started the engine and let it run for a while.
    Pull the dipstick again. The oil is still colorless.
    Can anybody explain where the dark brown oil from the 4.5 quarts sitting in the engine oil disappeared?
    I see there is still some dis believers..
    Ok, first let me state that they don't like the timken test? WHY? cause they don't hold up especially the new mobil super antiwear oil.
     Ok, notice, And I love this part, as quoted...
    "These tests are low-cost tests generally used to determine the performance properties of grease."
     I agree, the 4 ball is a grease test, the timken can be used for both.
    "They do not correlate with engine performance tests. For example, the use of an additive such as lead naphthenate would yield excellent results in these bench (or lab) tests, but would cause excessive oxidation of an oil in an engine and would cause a motor oil to fail the industry standard oxidation test known as the Sequence III test."
    now if this was the case, they would fail the seq III test, so some of the oils that are being tested are api certified and did not failing the standard api seq III tests so there fore their barrier lube properties do not cause oxidation problems.
    Simple explanation is, api does not test for barrier lube shear strength but does test for base oil limitations as for metal compatiblilty and base oil qualitiy for duration and oxidation resistance.
     for more on TBN's I created a new page to explain how higher tbns are not a good way to determine a good oil.
    let me know what you think.
    bob
    http://www.bobistheoilguy.com/basic_lubrication_design.htm
    ocelot1 read the 'test results' on the Amsoil vs'Valvoline Maxlife, and came to the same conclusion that Amsoil should have....they picked a fight with the wrong Oil.
    It's embarrassing! Here's the self proclaimed Heavyweight SuperSynthetic Oil of the World, own test results, barely squeaking by on a few points, against a $1.99 a quart conventional Lube.
    They even threw in a mention of a 4Ball test! Surprise suprise, Amsoil actually has one of these things. You would never know it from the lack of company 'wear' data comparing the Amsoil Lubes to the other Synthetics out there hustling for your $5+ to $9+ a quart business.
    Mobile 1 takes an even Lower Road in all this. (#3281) Their site implies that Oil comparisons in all these cheap wear tests are of no concern to anyone, don't mean a thing, so, Don't Woory, Be Happy!
  • fredvhfredvh Member Posts: 857
    Maybe you could enlighten us a little on the types of oil. What grade (SJ, etc.) does Toyota recommend now for the 2002 models? Was there an SK? How does one know what the difference is between SJ and SL? How do YOU know what the difference is? Can you mix them when doing an oil change? Can I have your opinion on 5W30 vs. 10W30? Is there a difference in brands of oil? Thanks in advance for your answers.
    maybe it would be to your advantage to goto this site and look around. I think it will help answer most of your questions you ask and might help you better understand oil in general as you seem to be looking at all these different questions. I also think it will give you a better understanding as to how one knows what they know.
    Thanks Bob and I will do just that. I was not aware that you had a site.
    does anybody have an explaination?
    How come a quart of new oil changes the color of old 4.5 quarts of old oil?
    /* I am no scAmsoil dealer...i brought six bottles out of my own curiosity */
    I just drained and refilled the drive hub on my Valkyrie with KLOTZ full synthetic hypoid. It is rated GL4 and GL5. I used the same product in the differential of a Plymouth Sapporo many years back. It is great stuff.
  • armtdmarmtdm Member Posts: 2,057
    However, my understanding is that a GL-5 gear oil cannot necessarily be placed in a manual transmission calling for GL-4. Not like motor oil where backwards compatibility (ie: use an SL in SF, SG or SJ application etc)is normally okay. My rear end diff calls for a GL-5 but tranny and front Diff are GL-4. Opinions seem to say a GL-5 formulation may damage a transmission where GL-4 is called for.
    rear ends are normally GL-5 accross the board.
  • afmbguyafmbguy Member Posts: 19
    Anyone knows where to buy mobile-1 0-40w in east coast ?
    Your response is greatly appreciated. I know some shops in New york areas charge mobile-1 5-30w, 5-40w...etc (except mobile-1 0-*W) for around $4.65.
    Your response is greatly appreciated. I know some shops in New York areas charge mobile-1 5-30w, 5-40w...etc (except mobile-1 0-*W) for around $4.65.
    Notice they use the word 'generally'. As Bob pointed out, the Timken test can be used for both oils AND grease. I also love the way Mobil derides low-cost tests. Hey, not every company has millions of dollars to throw away every year. And, when that money is spent appeasing the EPA with ill-fated schemes like ultra-low zinc and phosphorous formulations, it does not benefit the consumers who are fooled into thinking they are buying extra protection when purchasing Mobil 1.
    They do not correlate EXACTLY with engine performance or other tests ... but practically no single test does. BUT the Timken shows the ability of an oil to prevent wear ... which is what we all want from a synthetic oil. One simple test that shows the ability of an oil to perform one simple (albeit critical) function. No one is saying the Timken test is the last word in lubrication testing but its results are telling.
    This sounds like a classic red herring. Who uses lead naphthenate in their motor oil? Anyone? I don't think any company currently uses this and Mobil knows this. This is a classic red herring or straw man argument. Invent an issue that doesn't exist and then solve it in order to portray your product as superior. If you assume, as I do, that most oils on the market today (especially synthetics) adequately protect against oxidation, then this is a phoney argument.
    Yes, and we know that the API are a bunch of bureaucrats first and engineers second. These are the Dilberts who couldn't even come up with a functional definition of the word 'synthetic' for the industry to use. Thanks, but you'll have to excuse me if I don't revere them as though they were gods. As for the auto manufacturers, they seem all too eager to grab their ankles in order to please the whims of the EPA at the expense of long term durability of their vehicles.
    --- Bror Jace
  • rbaker377rbaker377 Member Posts: 7
    I have new GMC Envoy which is due for its first oil change (3000 miles). I want to use a synthetic and change every 6mo. or 8000 miles or so, even though GM says you can go further even with dino oil. I am inclined to use Mobil One, but a friend will sell me Amsoil for just a little more. Which is better?
    As a trial. Should be under $4.45/quart
    OK guys calm down a little. I was just posting what Mobil had to say on the subject. I'm just trying to see where the new Mobil formula fits into the world. I have had great success with Mobil in the past and know of many other people that have also. I have seen engines torn down that have used Mobil1 and there was practically no wear and the inside was very clean. They are one of the few oil producers that actually do tests on their oil in engines and then publish the results(I know that some are with older formulas and not under actual "real world" conditions) but they provide a hell of alot more than most others.
    As I understand it the Timken machine runs at around 850 RPM on the benchtop and you measure the pressure required to produce measurable scoring on a bearing not the stall load. I just don't see how this can tell me how an oil is going to provide protection in an engine at operating temp and 5000 RPM. Also what about testing on oil that has a few thousand miles of hard service on it??
    Seems like Castrol now has in production a new "Longlife Oil" Extended factory drain intervals of 2 years or more with this new OEM fill. The following are a few lines out of a publication called 'BP-Frontiers' released, yesterday April 14..
    Northern Europe is recognised as the most demanding environment in the world for
    motor oils. High efficiency engines, high speed driving, tightening environmental
    controls, innovative automobile manufacturers and knowledgeable consumers, all
    combine to demand the very highest levels of &#145;liquid engineering&#146;.
    Against this backdrop, the &#145;impossible dream&#146; for car owners and car manufacturers alike, is for an engine
    oil that offers improved fuel economy, multi-year service intervals, and is suitable for both diesel and
    gasoline engines. However, within BP Castrol the word &#145;impossible&#146; is taken as a challenge, and the recent
    completion of a five-year collaborative development with the Volkswagen (VW) group means that the
    &#145;impossible dream&#146; has just moved a very significant step closer.
    Over the last nine months Castrol has been
    supplying the VW group &#150; VW, Audi, SEAT and
    Skoda &#150; with a service fill oil, for all makes and
    models, that meets the car manufacturer&#146;s
    specifications for extended drain intervals and
    increased fuel efficiency. The new oil allows the
    VW group to offer its customers service intervals
    of up to 50,000km for diesel engines and
    30,000km for gasoline engines and is referred to
    as the &#145;longlife service concept&#146;. Not only does this
    offer the motorist the convenience of less
    servicing, it also reduces considerably the amount
    of used oil for disposal.
    You can access the rest of the info by searching for ..".Castrol SLX Longlife ll"
    Quite a feather in Castrols Cap to get this product in the VW crankcase before anyone else. I would love to know who the other companies were in this project , that tried, but didn't make the cut.
    "I agree, the 4 ball is a grease test, the timken can be used for both." (bobistheoilguy)
    So of course Bob, you're method is the only valid one and companies like Amsoil have it all wrong and are performing smoke and mirror acts and misleading people right?
    I have read alot of your posts here and find it quite humorous how you have developed the following that you have. Your Timken tests are extremely unscientific and as you well know, show (at best) only one of many required properties of a good motor oil. It really does not sound as though you are following any standard at all for this "Timken" test.
    On your own forum you have some very good examples of equally unscientific comparison testing. Do you really think it is valid to show oil analysis data from single samples, compare them and proclaim a winner when the difference in wear metals is a few ppm? E.g.,in your Dodge Cummins example, you are showing data from single samples, one Amsoil at 14724 mi., the other Schaeffer at 13455 mi. The Amsoil wear metals were virtually identical to the Schaeffer despite the fact that it ran more than 1000 mi. more. What really suprises me is that Schaeffer did not kick the [non-permissible content removed] out of Amsoil's wear numbers given that your "lab" has shown this soluble moly technology to be so clearly superior.
    By the way Bob, ASTM D 4172 (four-ball) is one of a few valid ASTM tests for lubricating fluids and you will find that many companies such as Chevron, (and others) do use it to test the anti-wear properties of compressor and hydraulic fluids, for example.
    See this Test Standard Index:
    http://www.plint.co.uk/at2/index/Stds.htm
