LS400 makes brief rapid clicking noise when engine first starts
My Lexus LS400 just started making a brief, rapid clicking noise like one of those electric screw drivers that has been set way down so that it won't strip the threads. It only lasts a couple of seconds and sounds like it's coming from near the fan. It only happens when the car has been sitting for at least a couple of days. It never happens once the car is running or on subsequent starts.
Any thoughts as to what it might be? I'd like to get some ideas before I take it in to be looked at.
Thanks, -J
Thanks, -J
I've had alternator/battery problems in the past with another car, but this seems like a different sound -- a bit softer. I guess it could be the same thing.
If it was the battery, wouldn't it happen pretty much all the time?
I just had it in for the 6 month service about 4-5 weeks ago. They checked the battery at that time and said it was fine.
I'll try to notice exactly when it happens the next time it does happen.
Thanks, -J
Beyond this you will need to describe the symptom to a shop and plan to leave the car overnight so that they get to start it and hear the noise and try to get a location on it before it stops happening.
Overnight is probably not going to do it. When I drive the car at least every 2-3 days, I rarely, if ever, hear it. It's only after it has been sitting for several days.
Is there some part that needs to be kept oiled and for some reason the oil is draining off after several days?
You might also listen for some valve lifter noise coming through the valve covers. A weak hydraulic valve lifter can bleed down overnight and would need to pump itself up--resulting in a few seconds of tapping noise.
My current guess is that the starter is staying on or engaged after the engine starts, resulting in the clicking noise for a couple seconds.
I am hoping you found the problem so i don't tear into my engine without knowing for sure what the problem is.
