2014 Dodge Dart Transmission / Clutch
Help needed. I am an owner of a 2014 Dart manual transmission. At 30,000 miles I thought I was having a transmission problem. I took my car to Dodge and they told me it was my clutch, fly wheel and several other things. My Dart was out of warranty ( over 12,000 miles). Dodge repaired it and said it was a courtesy and charged me $500. About 1500 miles later the same problem occurred and Dodge is now refusing to fix my vehicle because they say it is out of warranty and the first time was a courtesy. Dodge wants me to pay over $2000 to repair my Dart. I believe that they should repair it because the new parts should be under a new 12,000 mile warranty.
Very confused and displeased anyone have any advice on what action I should take. I thought about a laywer but not sure if I have grounds.
It's a mess and it's going to take some effort to straighten this out and get a clear picture.
Were you able to shift it out of sixth gear or not when you first had this problem occur? Once it cooled down, are you saying that with the engine running you couldn't shift the transmission into any gear? If that is correct, could you shift it with the engine not running? If those statements describe the car's symptoms then that sounds like the clutch won't release. That means it has either suffered a mechanical failure of the pressure plate or clutch disc or else you could have a clutch master/slave cylinder, or throw-out bearing issue.
With multiple clutch failures at such low mileage one of the prime suspects is the driver and the drivers operating habits.
Chysler should fix this problem before someone is injured.
