2007 Vue Electrical issues.....
I bought my 2007 Saturn Vue in March of this year. When purchased I noticed the radio didn't work, but thought if that was the only issue I'll live with that! A few weeks later I came out to a dead battery. The battery tested bad so I replaced it. A week or so after, I noticed it seemed to idle rough and I stalled out at a red light but was able to start right back up. (still idles rough to this day) The next morning the battery died again. I took it to a mechanic to get looked at and he suggested I take it to a local GM dealer that a code popped up that he did not have to equipment to fix. I took it to the GM dealer the next day, they had it a few days and told me no codes came up and they didn't see an issue with it. Since then it has died on me at least 4 times and I have to jump start it and it starts fine for a week or so and same thing over and over. I took it to auto zone again today to test the battery and altn. and battery tested good but needed a bit of a charge.... Any suggestions?
Just FYI it does have an aftermarket remote start and back up cam when I purchased it that seem to work fine.
Here are some photos of things you might see, maybe even signs of rodent nesting...
I would certainly start off by doing a PARASITIC DRAIN TEST. You can search for that on YouTube to give you an idea of what that entails. Basically you are looking for the exact cause of your battery drain.
If the battery keeps draining, your vehicle isn't going to run right.
Why don't you see if there is anyone on this list of high-quality technicians that is in your area? These people are properly trained to solve problems:
http://www.iatn.net/
Click on "repair shops" up top on the page.
These were my transient symptoms:
1: Instrument lights blinking off.
2: Instrument gauges not working or bouncing around.
3: Radio blinking off.
4: Turn signals don't work.
5: Turn signal activation disengages cruise control.
6: Cruise control cannot be set.
7: Car behaves as through battery has been removed (which also means that the key cannot be removed if you put it in).
These problems could usually be triggered by using a DC->AC power converter with a heavy load, like a laptop.
There were 2 problems with the battery connections.
1: The battery connections are of a poor design and do not allow for excessive (adequate) clamping so the positive terminal had wiggled loose. This was the main problem and made the care stable for a few weeks but then the symptoms came creeping back. So I went back to the battery area and found...
2: There is a very small gauge wire connected to the accessory lug of the Ground/Negative battery terminal via a very poor quality ring lug. The connection of the crimp to the ring was so week that when I gently pulled on it, it separated completely (see the 2 pictures: 1 before, 1 after). I stripped it back and screwed the nut directly onto the wire (did not yet replace with another proper ring lug) and have done 1000 miles with heavy load and no electrical glitches at all.
