2010 Acadia - A/C problems worse with outside temp increase
Cold driver, hot passenger side. Circulate has to be on and now rear to get cooling when it is NOT hot outside. Checked fuses, cleaned and swapped clutch with horn relay. Rear unit does not blow air or feel cold. I have insurance, but it does not cover sensors, switches, etc. only compresse, condenser, evaporator, blower, clutch, temp control programer, air ducts and orifice tube..When it was working intermittently it worked well, but I plan to check fluide next.. I want to make sure it is something I can fix or low cost before using insurance.
Thanks in advance for any help, Robert
