Buick Regal GS Power Window and Radio Issue
amommy4life
Member Posts: 6
I recently purchased a 2002 Buick Regal GS. The previous owner cut the wires for the sunroof and mirror (I have no idea why). The windows worked and radio worked until yesterday. We touched the wires sticking out of the headliner and may have shorted something. Now, the power windows don't work and strangely neither does the radio. Any help would be greatly appreciated.
If you "touched wires" I assumed that means you connected them or shorted them to ground not knowing whe they were? Could have done damage to something.
In the instrument panel block there may be more than one circuit breaker with the SAME part number on it. That other one and the one for the windows/roof can be interchanged to see if it's the circuit breaker not reconnecting after being tripped.
The radio has two fuses in the instrument panel block, a 2 amp J7 J8 and a 15 amp E1 E2. The letter and number likely are the row and column locations. The lid of the fuse block will have diagrams showing shich fuse is which. Also there's you owner manual in the glove box.
If manual is not there diagramming locations, the manual can be downloaded under Owner on the buick website.
Any other suggestions?
