13031333536164
  • mjday1972mjday1972 Posts: 76
    Have you talked to your dealer about it?
  • tonym182tonym182 Posts: 1
    Please contact your Toyota dealer's service manager to schedule an appointment with the DSPM-
    District Service and Parts Manager. If the paint is as bad as they claim it to be, than there is a good possibility that they will fix the problem for you, as the car has a warranty on corrosion and paint for 5 years-60k miles. Also, ask them what they recommend as far as paint protection goes, maybe they can suggest a superior product to coat your paint with.
  • Would have the 'thump'(could feel and hear) first shift into drive after reversing from driveway. Service said this is normal for V6. My problem was with the brakes. Brakes failed, service checked out "everything okay." Then brakes started to sink to the floor at long stop light, service checked out said "all okay." I was terrified of driving it and asked regional rep to work with me toward an Avalon as I was not going to keep this car. Was offered an extended warranty instead hahahaha Took a $7,000 hit to get rid of it @1800 miles. Toyota makes a great car, but if you have problems you are on your own. Have had great Toyotas before, but after this fiasco will never have another one again. Also, gov't web site to check out consumer complaints, including Toyotas:
    www.nhtsa.dot.gov
  • curlyqcurlyq Posts: 54
    My 2000 Camry Solara suffers from excessive paint chipping, but not the way you describe it. When the district guy came out he was looking for specific signs of defects in the paint and traditional rock chips didn't make the cut. I agree, you should demand the district guy look at your car. I too agree, this will be my last Toyota!
  • petrnycpetrnyc Posts: 47
    Have you noticed how active this particular board is. Every time I log in this board appears on top of the active boards list. Oh what a feeling - Toyota !
  • My wife and I were driving back from NY to MD this weekend when into about the 4th hour the A/C stopped working. We had it just below full blast the whole way. A few hours after we got home, she noticed that water was still dripping from underneath the car. When I started it up this morning, the A/C was working again. Any ideas?
  • wainwain Posts: 479
    did air stop blowing out?
    could have frozen due to low charge
  • vchengvcheng Posts: 1,284
    would be freezing of the refigerant at the expansion orifice due to an improper oil:refrigerant mix, leading to warm air blowing out.
    Of course, as wain points out, it could also be freezing of the evaporator coils leading to blockage of air flow.
    If it continues to happen, a visit to the airconditioning shop with checking of pressures etc. may be required.
  • rsaligerrsaliger Posts: 6
    I have a 2002 Camry SE V6 and I experienced the same problem. I returned the car for the second time and they replaced the electronic control unit (ECU) and the car stopped hesitating at 40-45 mph. Since they couldn't find the problem the first time, the after effect now is there is a cluck in the transmission when I let off the gas and go to accelerate again @35-50mph. Again they can't seem to find the problem and say it is normal. 17,000 miles on it since Oct. Might just trade it now. Tired of messing with them.
  • 8u6hfd8u6hfd Posts: 1,391
    You know dealerships don't need to replace ECU's anymore for the 2002 Camry.
    They can be basically be overwritten with the new code.
  • alpha01alpha01 Posts: 4,747
    Yo guys (and girls, perhaps) I'm new to this thread, so thanks in advance. Our 2002 Camry has been absolutely awesome overall-much improved over the 97-01 gen.
    The ONLY problem I have with the car is deciphering which is the BEST maintenance interval for the car-there seem to be about 4. Ours is an LE 2.4 auto, so I am not concerned about sludge since that family of engines has never shown a high incidence. Currently, we are doing servicing every 5K miles, and are now at the 10K mark. The maintenance brouchure that accompanies the owners manual says that 5K or 7500 mile intervals are sufficient, but the dealer (naturally) wants the money, and recommends either every 3000 or 3750 miles, depending on which service shiester you talk to. Is every 5K really not good for the car- our oil looks clean to my untrained eye, and its a major inconvenience (as well as an added cost) to make extra trips to the dealer. If its worth it, thats a different story. I realize this may not be the MOST appropriate thread in which to pose my question, but it seems the most trafficked of the Camry ones on this "maintenance and repairs" boards.
    Again, thanks for you input.
    ~alpha
    The best way to tell is to spend $15 to $20 for a oil analysis test.
  • andrelaplumeandrelaplume Posts: 934
    I am interested in installing the Toyota brand mud flaps. They come only in grey. Has anyone installed these themselves? Is it easy? How do they look? Are they worth it.
    I am still interested in the 3M invisible nose guard mentioned several posts ago. Again, I am looking for pricing and general info as to what it looks like?
    Finally, We finally got some rain up our way in PA and I have found the rain drips in quite a bit when the door is opened. How do those rain guards work? What brand would I buy? What do they cost? Do the stay put? Do they create wind noise? How do they look?
    Any input is appreciated!!!
  • similtonsimilton Posts: 1
    Our 97 Camry recently threw/blew a rod (not sure of proper terminology) that put a hole right through the engine. The dealer insists that there was no sludge on the top of the engine and that the problem likely occurred because the car is 5 yrs. old with 120,000 miles. So, they refuse to cover it.
    I've been reading that a Camry is good for up to 200,000 miles with/ proper maintenance, which we have been doing and can fairly well document.
    A few questions...
    Is high mileage the really the most likely reason for the engine's failure?
    Can sludging cause our problem?
    Is sludging likely to occur internally?
    Should we get a second opinion from a Toyota dealer or an unaffiliated mechanic?
  • alcanalcan Posts: 2,550
    The most common cause of rod bearing failure is lack of lubrication to the bearings. Possible causes: low oil level, restricted oil pump pickup screen, defective oil pump, contaminated oil.
    Teenagers who never check the oil. neighbor kid got back from college, Honda - no oil showing at all on the dip stick
    When the dealer changed the code on the ECU to stop the hesitation (which they fixed), can that be the reason now when I let off the gas and accelerate again (45-55mph) there is a "cluck" in the transmission (which feels like it is catching up and locking in)? It's as if the timing between transmission and engine been altered. This problem didn't start until I picked it up from the dealer when they fixed the hesitation. Thanks for your help in advance!
  • michaelm10michaelm10 Posts: 11
    My 2002 Camry XLE is equipped with the remote control trunk release. When activated the trunk only opens an inch or two and not two thirds of the way that my Honda Accord EX did. Toyota service tech advises that the trunk is only supposed to open an inch or two. Would much appreciate any input from other 2002 Camry owners with like equipment.
  • guevinjguevinj Posts: 15
    My '98 Camry's front suspension made the same creaking noise described in many of the posts here. At 26,000 miles, the dealer replaced the front upper strut mounts, as described in a Technical Service Bulletin (TSB), under warranty. My car now has 37,000 miles on it, and the same creaking/groaning noise is back. It's especially noticeable when I go over speed bumps. When I press down on the front corners of the car, it creaks like an old taxicab.
    I just had the car in for service at the same dealer who had done the work. They said the front struts looked fine, were not leaking, and they didn't hear any suspension noise on the test drive. I think they just don't want to pay for another set of front struts!! Could the replacement struts actually have gone bad after only 11,000 miles? The car is driven very gently. Has anyone else who has had their front struts replaced had this problem return? I'm thinking of bringing the car back to the dealer and insisting they fix this problem without cost, even though it's past the warranty! Am I crazy to expect this? Struts certainly should last longer than 11,000 miles, shouldn't they?!? What's the point of TSB's if they don't fix the problem? Or, could something else (i.e., bad shocks) be causing the creaking sound? Any feedback would be appreciated. Thanks!
  • ianfianf Posts: 1
    For the past 1.5 years my 97 Camry produces an annoying rattle from the front left&right at low speeds. At the 60K maintenance the Toyota service folks told me my brakes needed replacing. Replaced the brakes at Just Brakes a month ago but the rattle still persists. The car brakes just fine but Id love to get rid of the rattle, its just terribly annoying. Any suggestions???
  • 2002camry2002camry Posts: 20
    I recently purchased a 2002 Camry XLE V6. I love driving it. It's smooth and powerful. I've been hearing wind noise coming from the center pillar. It seems that whenever I get above 80km/h (50mph) I hear wind coming from what seems to be the adjustable shoulder belt mechanism. Anybody out there experiencing a similar thing. Solutions anyone????
  • Our 99 Camry had the same problem on left front strut. The dealer replaced the front upper strut mounts, but I noticed the noise still there. So I called next day and scheduled another check. This time they replaced whole set of left front strut under warranty, and the noise was gone. Now we are worrying about the right front strut since the warranty will expire soon.
  • FYI.
    Brakes - Pad Clicking Noise
    BRAKES
    BR004-00
    October 20, 2000
    Title:
    BRAKE PAD CLICKING NOISE
    Models:
    '90- '00 All Models
    Introduction
    A clicking type noise may be noticed when first applying the brakes after changing vehicle travel direction (Drive/Forward to Reverse, Reverse to Drive/Forward). This is a normal noise caused by the required brake pad-to-caliper clearances. When the direction of travel is changed, the brake pads may "shift" towards the new direction of travel. When the brake pad contacts the caliper, a clicking noise may be heard.
    To minimize this clicking noise, a disc brake caliper grease has been made available for use during brake service/maintenance operations. Under normal usage conditions this grease should be effective for a period of 6 months to 1 year.
    Applicable Vehicles
    1990 - 2000 model year Toyota vehicles, all models.
    ...coming from the car stereo area...quiet sometimes rattles others. Anyone else have this and/or a solution?
    (Also have vibrations at ears level by seat belt adjusters on doors)
    I have a 2002 Camry XLE also and my trunk opens approx. 8-10inches using the remote or my keys. I think the amount it opens depends on the two cross spring that I see near the rear or the trunk. But I'm only guessing.
  • rbrooks3rbrooks3 Posts: 174
    My friend has a 1997 XLE and I am at a loss to help him. He recently, only twice, has found water, about 1/4-1/2" deep in the rear passenger side footwell. The water is clear.
    We assume it is either coming in from the moon roof or the drains for it. But we can't find the leak. Putting water over the car does not make any water we can see come in the car. Once again, let me say the water is only in the rear passenger's side.
    Does anyone know where the drains are for the moon roof?
    Ron Brooks
  • Love my 94 Camry, 93,000 miles problem free. OK, 2 minor problems that I'm looking for advice on. First is the antenna does not completely extend when switching on the radio, and reception is hurting because of it. Second is the ABS light is on and they don't work. Is that worth getting fixed, and if so, by whom?
    You're in for some expensive repairs.
    New antenna mast and motor. Ouch
    ABS, get it fixed...may prevent an accident.
  • jdeibjdeib Posts: 70
    The Antenna Mast needs to be replaced. I think every Camry from that era that had the power antenna had this problem. I had the same problem on my '92 about three years ago, and the Toyota dealer charge to replace the antenna was about $65.
    I don't know about your ABS, but with my '92(non-ABS), the brake light kept lighting up when I would go around curves. It turned out that my brake fluid was a bit low, and the sensor would trigger when the fluid would slosh around on the curves. Hopefully it's that simple.
