A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Can anyone tell me precisely WHERE I would then FILL these two vehicles with the differential fluid ?
Hope this helps.
You can also do your claim on the internet at www.continentaltires.com.
I hope this helps.
The owners manual says to use DEX-II ot DEX-III fluid. The manager of the parts dept sold me TYPE T-IV and insists that it is okay to use this because T-IV supersedes all of the other fluids.
What do you think ?
Thanks in advance for any input.
When the car runs, the alternator takes over and charges the battery if needed. Did the charge/battery light come on while you were driving? Your new battery will drain fast with the headlight on.
It just goes to show you. YOU have to be the policeman on YOUR vehicle. It's hard to find someone or a repair shop that you can REALLY trust. It just so happens that I am mechanically inclined and have always enjoyed working on my own cars. But as I get older I find that I don't have as much time as I used to to do this stuff. This is also the first time that I have a NEW vehicle, and a LEASED one at that.
That's all I would need is to turn in the leased Solara 2 years from now and have them say to me that there is something wrong with the tranny and they want my records of maintenance. Then I would show them that I did it myself AND used TYPE T-IV fluid. They would hit the roof !
Well, I'm going back to that Toyota parts manager tomorrow in Green Brook, NJ to give him a piece of my mind. I'd like to see what response he has when I show him the TSB !
What I also intend to do is to randomly call 3 other Toyota parts departments and see what they tell me. I'll ask them straight out if I can use T-IV instead of DEXTRON III (when only removing 4-5 quarts).
Let's see what they say !
zguy in AZ
The wires had very fine, subtle cracks in a few places. There were brownish burn spots on the wires indicating charge was leaked between wires.
After taping up individual wires with electrical tape, the battery draining problem is gone!
The car is still under warranty but the dealer insists that there is nothing wrong with the alternator.
I checked the charging system with a voltmeter. It did read between 13 and 14+ volts under load at 2000 RPMS. I think it may be an intermittent problem. I did notice recently a fairly severe vibration when using the air conditioner on high in traffic for a long time.
Will keep checking and I may bring it to another Toyota dealer for a second opinion.
Thanks for the feedback.
There has been no improvement, it may even be worse. Has anyone else experienced this problem? Thanks in advance.
If you have a 4-cycl., I would expect a slight a vibration when the A/C is on and stuck in traffic.
I think the smell must originate from my car, because there is no car close to me. Another problem the steering is not very easy when I park my car and press the brake. Honda's steering is very easy.
Which one you refered to ?
Drove from Idaho to Texas for the summer. Once in Texas it'd crank but wouldn't start on first try, always would on the second, (not enough gas injected?). How do I fix this? Once it started it would idle/run perfectly. After two months of this the transmission (up/down shifts) became jerky this morning. Not violent but definatly noticable.
Are these problems related?
I regularly change the air/oil filters. Found I filled the oil 1/4 quart high last week, I drained down to normal today. Gas tank is 3/4 full. Transmission fluid is at a good level/color. Checked for other leaks (paper under the engine overnight) but found none. Don't think it's the fuel filter-changed 18 months ago. I'm gentle on the car, HOPE the transmission isn't going out.
What's wrong with the starting and jerking? Any help would be appreciated!
Thanks!!
1) Water has been leaking into the right rear footwell, creating a little puddle that makes splashing noises when I turn quickly. The water is clear, and sogs up the area after driving for a few minutes. I took it in to the service dept of the local dealership and after 2 1/2 hours' wait, they came back to me saying that there was a crack in the bottom of the car, allowing exterior water in from the bottom from puddles, etc (it has been very hot out here in Miami and I have definitely not been driving through any puddles). They said it would require welding and sealant at the auto body shop, and at least a day and a half so they could remove the entire carpet, and shampoo and dry it, but that they can't touch the car until Tuesday due to the long weekend coming up. I think this is ridiculous. From doing searches on this forum it appears to be related to the A/C or drain hose. Has anyone else encountered this problem? Any suggestions on how to deal with dealership service departments on it?
2) The alarm system's red LED light in the dash usually does not blink when armed (but blinks every once in a while). The alarm has been acting up, pretty erratically, and goes off sometimes when I am merely entering the car after disarming the alarm.
3) Rattle that occasionally occurs in the front passenger side-curtain-airbag area.
4) Driver's side automatic window does not go down automatically when pressed, though sometimes on good days it will go down automatically.
5) To unlock all the doors of the car, must press the unlock button on the key 3x instead of 2x.
Any suggestions on how to go about dealing with all of these problems? Any help will be much appreciated.
I wouldn't want a car with that kind of problem no matter IF they could "fix" it....
Just my two cents worth....
Deke
Thanks for your two cents. I got a second opinion at another Toyota dealership and they're pretty certain that there's a hidden A/C vent beneath the rear passenger floorwell that's causing the water to pool up. By this point I think there's a fair amount of water beneath the carpet because whenever I stop or turn suddenly, I hear what seems like a gallon's worth of splishing and splashing.
The second dealer is very doubtful about the existence of a crack, but the first dealer's mechanic said that when he lifted up the car, a lot of water was gushing out of it. It's not visible per se, but clearly exists. It might be an area where two parts might have come together, and the glue/sealant wasn't properly keeping it together, but I'm not sure.
I looked up the lemon law here, which requires 3 attempts at repair, ultimate inability to repair, and substantial impairment of value before being able to get a replacement vehicle. Do you think the dealership from which I bought it might replace it? I'll probably drive the vehicle up to him - he's about 2 hours away - to get the repairs done. Despite the fact that the carpet will have been sitting in warm water for at least 6-7 days, the local dealerships refuse to replace even just the carpet or mats...
Does anyone know if it's the motor or I heard something about a window regulator. What is that?
Try calling Toyota directly and see what they say. They can authorize a buyback or an exchange. If the dealership doesn't let them know about a problem, you have to.....
Good luck....
Deke
Do you know if there were a TSB for this trans problem ?
I've driven other SE's which are a pleasure to drive. Toyota tells me their is no problem with my car. Is anyone else with an SE experiencing these problems?
I recommend to reduce pressure on rear tires by 1-2 psi since the rear is much lighter than the front car.
and the shifter seemed to have a little more resistance when moving
from park to reverse to drive. Could there be any issues with the
transmission. the transmission itself shifed smoothly.
Your sensitivity to this attribute does not necessarily make it a design flaw. It actually is something that you should have been checking for on when test driving the various makes. But I think you will find that most sedans today have high trunks.
When I'm not sure about parallel parking, here is what I do to make sure I don't scrape the curb(or bump the car behind): Angle the power side view mirror down until you see the curb, it works great. Some luxury cars now do this automatically for you. The only pain is that you need to return the mirror to your best angle when done.
back near the firewall like in the Sienna) or straight (where 3 on one
side and 3 on the other). With the latter it easy to change plugs while the former its darn hard to get at the rear 3.
