Never had a car that did this before.
It seems to be getting better over time.
Car now has 2100 miles on it and the lurch is still there but
much gentler.
It used to feel like it was always being rear-ended when I stopped
at a light, which was not a good feeling as it would cause a panic reaction
in me, having been rear-ended three times in the past.
I love this car otherwise except that every other car on the road looks just like it.
I got the "superwhite" color, so bright it almost glows in the dark.
Stereo in it is VERY bass heavy, guess they think we all drive around with the bass pounding away.
For a four cylinder it sure is PEPPY, especially on the highway where we all cruise at 90 mph here in south Florida. Cruises like a six cylinder. Power to spare.
http://townhall-talk.edmunds.com/direct/view/.ef4cdbd/1070
I have 2000 camry V4 with 100K
A note that when this first started about 8 weeks ago, I thought it was the transmission, I have 157K miles. Then, 2 weeks ago, reverse started to slip very bad, then the overdrive button didn't work when I wanted to use 3rd gear to help slow down. I had a used transmission put in. But the jerking is still there.
Hope I can help.
Thanks...
I mentioned this problem to service guy, he said " wait until 1000 miles over break-in period". Now the car has 20K and it's still jerky.
Brought the car to Toyota dealership twice, nothing they can do about it.
It's design flaw and Toyota could not figure out to fix it. There were several TSB about transmission and none of them could fix the problem. :confuse:
They say that I must take it to a toyota dealership. The nearest one is 50 miles away in Montgomery, Al. I am getting NO CO-OPERATION from these Goobers. I want to know if anyone else has experienced the Check Engine light problem with their 2003 Camry? Did I buy a :lemon: ?
There are several 1997 - 2002 Toyota and Lexus models affected (including 1999 Camry) that are covered under a free repair policy that is for 8 years from the original purchaes date, unlimited miles. I am pretty sure buyers of used vehicles are covered too, however, to get your engine repaired for free, you are supposed to provide proof of reasonable maintenance -- unless you have the maintenance records of previous owners, i don't know how you would do this. To positively identify sludge, you will need to get someone to pull the valve cover.
If break fluid level is low it means couple of bad things, such as leakage or very thin break pad etc so usually technicians at autoshop see low break fluid level, they would also check those parts.
Refilling break fluid would stop them from doing that, it might be just masking the real problem.
Is it likely the struts need replacing?
Is it a job I can tackle?
link title
Not without a spring compresser. Plus you can't do the alignment afterward either (I assume that was included in the quote you got.)
Try resetting the sensors by removing the battery's negative terminal, waiting 10 seconds, then reinstalling it. If that will not clear up the warning light, you should bring the car to Toyota dealers who can diagnose the problems with their computerized test equipment.
You should try to clean the radiator innards with one of those calcium desolving detergent. It worked for me.
The dealer wanted to replace the water pump, radiator, fanetc.. which totaled about $2,000. My solution costed $5.00.
Always use only distilled water, never tap water, for your radiator.
I have a 99 camry LE with 65k. Fixed a flat tire and had it balanced recently. Then I feel vibration from under seat when driving around 50mph, especially after I step the brake and then hit the gas to speed up. The vibration is gone above 60mph.
Also, a couple of weeks ago I did the state inspection for title registration. The inspector noted "noise in timing belt area". There is kind of rattle sound seemed from engine, which is obvious at 40-55mph. The manual says replacing timing belt every 60k, but I know many people didn't replace it until far above that. So what will it be if timing belt is about to break, so we'll know it needs to be replaced? Also, could the vibration mentioned above relate to timing belt problem?
Thanks for your consideration,
Jeannine Fallon
Corporate Communications
Edmunds.com
Went to the shops this weekend,first shop i went to they charging
me $372.00 to replace the rotors and the pads, but my pads are still good
they still looks new they said i need to put a new pads also to resolve the problem.
Went to 2nd shop said its gonna cost me $200.00 something plus tax,also said that i need to put a new pads.Do i have an option to just replace the rotors and keep the pads?I need some advice.
also i am interested how to change the brake pad.
Is the tire worth saving? If so, you should definitely go back to the tire repairer.
Timing belts give no warning about when they are about to fail. The "rattle" is NOT being caused by the timing belt. You cannot even tell by looking at the belt if it's going to fail. In all probability, if you replaced your belt now, you would not be able to tell the difference visually between the old and new belts.
If the belt were to fail, you'd be stranded on the spot, but there would be no engine damage, at least if you have the 4-cylinder (I think but am not certain the same would be true for the V6).
It wouldn't hurt to replace the belt now, since age as well as mileage play a role, and your car is 6 years old. I'd use a reputable independent shop rather than a dealer.
In you case it looks like has ripped you of,you could have lived with a little bit of oil leak if it has increased lick it means the gasket replacement isn't done properly, get on him about that & tell him it shouldn't be leaking any oil.
For next time for such works take it to dealer, Toyota Service stations are not that expensive if we put it with the quality of service & piece of mind we get, also if your car is leaking to much make sure you keep checking oil & don't run out of it while you are driving.
Also, all the cars I own are Toyotas/Lexus, I had one Nissan Maxima which really sucked with maintenance cost, so I sold it & I am a complete Toyota Guy now.
So you say Toyota used non-interference engine for 99 Camry then the engine would be ok if timing belt breaks? That's definetely good news. My car is 4-cylinder. I think I'll change timing belt in a couple of months.
Yes, the 97-01 Camry's 4-cyl. engine is a non-interference type, which means the engine won't be harmed if the timing belt breaks. Of course, you might be, if the belt breaks in an unsavory neighborhood late at night!
I don't know for a fact but I suspect all Camry rotors are the same. There's not enough difference in weight between the different models to warrant different rotor sizes. There's at least 1" between my calipers and the 17" wheel so a 15" steel wheel would easily fit.
Not really, as I know the XLE, XLE V6, SE V6 have bigger rotors compared to SE, LE and LE V6. The 15" wheel would not fit to the option has bigger rotor.
I stand corrected then. Is this published somewhere or can you tell by looking thru the wheel openings?
Both, there is specs I provided below, also you can see 16" wheel has bigger rotor.
Here is the specs
Small rotor: 10.8" (15" wheels)
Big rotor: 11.7" (16" wheels)
Here is the link to Toyota's spec
http://pressroom.toyota.com/photo_library/display_release.html?id=2004camry_s
BR006-02 DEC 02 Brakes - Front Brake Vibration
"Under certain usage conditions, some 2002 – 2003 model year Camry vehicles may exhibit front brake vibration. The rotor and pad have been improved to correct this condition. The new rotor and pad must be installed as a set. The revised parts have been introduced into production."
�� 2002 – 2003 model year Camry V6 XLE and V6 SE vehicles produced before the
VINs shown below.
PLANT STARTING VIN
TMMK Line 1 4T1BF3#K#3U037796
TMMK Line 2 4T1BF3#K#3U544996
Tsutsumi JTDBF3#K#30103561
PREVIOUS PART NUMBER CURRENT PART NUMBER PART NAME
N/A 04002–18133 Repair Kit, Pad & Disc*
04945–33050 Same Shim Kit (JPP) (if needed**)
04945–06070 Same Shim Kit (NAP) (if needed**)
* Kit contains 2 brake rotors and brake pads for both front calipers.
** Visually inspect shims for heat discoloration. If discolored, replace the shims.
1. R & R the brake pads and rotors following the procedures outlined in the applicable
Camry Repair Manual.
2. Road test the vehicle.
OP CODE DESCRIPTION TIME OFP T1 T2
BR2006 Replace Front Rotors, Pads and Shims
(if Needed) for Vibration (Both Sides)
0.7 43512–33100 21 44
Applicable Warranty*:
This repair is covered under the Toyota Comprehensive Warranty. This warranty is in
effect for 36 months or 36,000 miles, whichever occurs first..."
Thanks for the link. Strangely, for the 2005 model it shows a rotor .1" smaller diameter for the 17" wheel vs the 16" wheel.
http://pressroom.toyota.com/presstxt/2005toyotakit/2005_Camry_s.pdf
