Can you put brake grease on the INSIDE part of the brake pad?
wisdomseeker1wisdomseeker1 Member Posts: 2
edited October 2017 in General
Where the brake pad meets the rotor a friend of mine was helping me with a brake job, when he insisted on greasing the pads... not the back of the pads, but where the pad meets the rotor. I'm confused I have never don't it this way before. Please help
Best Answer
  • thecardoc3thecardoc3 Member Posts: 5,876
    Answer ✓
    I have a saying, "Anyone can do brakes........ Incorrectly" and no you do NOT put grease on the front of the pads. Doing that has contaminated them as well as the surface of the rotor. You will need new pads again and will have to clean the rotor's completely. To clean the rotors at the minimum you will need to wash them down with brake clean and then wash the brake cleaner residue off with soap and water. (dish soap works well)
Answers
    Simple Green will also clean them up real nice after the Brake Kleen treatment. Toss the old pads away and at least consult a YouTube video next time.
  • wisdomseeker1wisdomseeker1 Member Posts: 2
    Thanks for the quick responses, I should have stuck with my gut feeling and just told him to stop. I have learned sometimes you just need to be firm with people.
  • This "friend" has given you the worst advice I have ever heard of!
