Toyota Highlander Dashboard Lights
in Toyota
When I turn on my headlights my dashboard illumination and clock go out. Anyone have ideas?
SUVs and Smart Shopper
What I do have left of the steering wheel is three little black covers where it looks like switches would go if one had bought the options for whatever they are for.
Ted Stevens
I know this is an old thread but when I googled "Toyota Highlander headlights on makes dashboard lights go off" its the first item that pops up on Google. So I had this issue on my 2007 Toyota Highlander and I too could not find this dimmer switch. So after some more googling I found a board that helped me. It is the same toggle that you use for your odometer setting....you know like when you are taking a trip of want to know how many miles you are traveling. Just adjust that until your interior lights come back on lol.....
if your dash lights are out above the radio on a 03 highlander you can either send the whole piece out for repair or try to do some soldering yourself. its the main connection inside the center dash control panel with the ribbon wire. ac switch light, rear defog switch light, and illumination for heater control dials wont light up. there are like 9 connections on each side of the piece that has to be resoldered need a straight tip solder iron, not instant on. and probly a magnifying glass!! ill try to attach a pic ed its the long black piece that has 9 soldering points. there are nine more on the other side! good luck. heat one at a time very quickly dont overheat it! just touch some fine solder when hot and keep going. once u get one soldered it seemed to stay in place pretty good i put the ribbon wire in while i soldered incase it would deform the ribbon connection point
LOL folks, i had the same problem last few months and knob was turned to the lowest. almost went to the nearby shop.
FYI, This is the variable switch that sits next to the mirror adjustment controls, closer to the door.
