whats going wrong with my transmission
start out in drive engine revs up to3300 RPMS/25MPH BEFORE SHIFTING INTO 2ND THEN REVS UP TO 3300 RPMS/45MPH SHIFTS TO3RD 2200RPMS 55TO 60 MPH OVERDRIVE
Answers
Sounds like you are losing internal pressure. Time to have it tested. Once seals get old inside, or wear tolerances widen, the transmission does a kind of "internal hemorrhage".
If you're motivated, you might drop the pan and look for metallic debris--good sign of worn clutches.
