Bluetooth turned off. 2014 Toyota Camry.
we just bought a 2014 camry with 4000 miles on it. i deleted the previous phones from the previous owner and then the bluetooth was turned off. one can see that on the screen unlit and OFF. does anyone know how to turn it back on? I went to dealer and they did not. there is no option to turn on. tried to set to default and nothing. need help please
Did you get a manual? Toyota has them online. (pdf file). If that link doesn't work, try this one.
Looks like you should have gotten there returning to the default but I'm no Bluetooth whiz.
thanks- have the manual. no mention of how to do that and the manager at the toyota dealer did not get why this i happening. common sense and logic says going to default should work but doesn't. have to wait until the tech people are back to work at toyota. closed today. thanks for trying.
On my 14.5 L and 13 XLE, I go to Setup and press Bluetooth. There is a pairing procedure you go thru where you turn on your smart phone and the car system and walk them thru a learning process. Nothing is automatic by using default.
Did you ever figure it out because I'm having he same problem. When i go to detailed bluetooth settings, the option to turn bluetooth on is grayed out.. i tried deleting all personal data and previously paired devices. When i try to just connect and search for my car on my phone or tablet, it can see the car multimedia and connect for a sec, but then it boots off and says device not supported. Ive tried everything, i just cant figure out why it wont give me the option to turn it on in the car
I had the same problem. I clicked on “Forget this device” on my iPhone and then tried to connect the phone again from the car. This time it worked and now my iPhone is connected to my Camry 2013 again. Hope it works for you all too !
From the phone and left the call audio - media audio and contact access pair ON and it fixed everything now , I am going to leave a picture of my phone setting showing what I mean turning the Message access turned off.
Advice?
Turn ignition to On, but do not start the engine, and let the radio power on. Then while holding in the "APPS" button, turn the head lights on then off 3 times (Seriously!) This brought up a diagnostic screen. In the bottom left corner, hold down the "INIT" button about 3 seconds and it will say something about personalize data, yes or no. I pressed yes, and exited out by holding in the radio power button, which re-booted the display. The Bluetooth & Phone links in my Settings display were working again.
This is a genuine fix!
I have been reading so many blogs, and trying so many different suggestions was about to lose my mind, when I saw this comment and had to reread it again because I thought it was a joke!!
I tried it, and BAMMM my Bluetooth is working and phone connected!!
Thank you so much!
PS THIS ACTUALLY WORKS!!
