Jeep Grand Cherokee Limited Turning problems
in Jeep
I own 2 JGC Limited's, a 1994 and a 1998. Both have a problem turning at slower speeds.
When I do the 'turn around' on a highway, I have to turn exceptionally wide, etc.
I've replaced the Transfer Case on the 98 and it didn't help. The mech told me it was the 4 wheel drive engaging due to control arm bushings, shocks, and uneven tire wear (after replacing the TC!).
This has to be a somewhat common problem as I have the same problem with both vehicles, I would think. Yet, I can find very little info on the matter.
Any suggestions or help would be greatly appreciated.
It makes sense, but what doesn't make sense is why (with both vehicles) it wasn't doing this from the start.
Seems it started around 150,000 on both if memory serves rightly.
They both have the QuadraTrac auto 4 wheel drive (or all the time 4 wheel). I haven't been able to find info on this matter and with me having the same problem with two Jeeps four years apart, I would think it is a somewhat common problem.
I haven't taken it to a dealer yet. Holding off as they want $50 to diagnose the problem.
Hopefully I'll find the answer here, first!
