Floor shifter and some indicator lights out
My light for my floor shifter in my 2008 edge Is out and several lights for indicators such as my hazard light button are out I have replace the bulb for the floor shifter to no Avail and I have checked all fuses that I know to find and nothing has worked I would appreciate some solid suggestions on what I could look to and look for to fix this problem
Best Answers
thecardoc3
Member Posts: 5,862
Power comes from fuse #10 (15amp) in the smart junction block at the left side of the dash. Inside the smart junction block is a semi-conductor relay (FET) that controls the power to the circuits you listed from the fuse.
The power connection at the smart junction block is pin 39 of C2280B (Violet/Gray) so if the fuse is powered up and good and there is no power at pin 39 then the failure is inside of the smart junction block.5 -
thecardoc3
Member Posts: 5,862
It is not easily replaced, most components like that are usually serviced by replacing the assembly. The fuse being blown is not a good sign, excessive current can damage the traces on the circuit board that is internal to the smart junction block especially if someone tried to over fuse it. There are times that repairing something like this is done by taking that circuit out of the block assembly, but it's not something that I would recommend for anyone that doesn't have extensive experience.kooljames said:I am also curious about the semiconductor relay that you spoke of And is that something that is easily replaced?
5
Answers
