Does the Chevy colorado 3.5l cut off engine when oil pressure is low
cableman3cableman3 Member Posts: 2
edited February 2018 in Chevrolet
Just bought 2008 Chevy Colorado after warming up engine cuts off at idle or while braking I was told low oil pressure was cutting engine off
Best Answer
    edited February 2018 Answer ✓
    No, that is not correct. You'll have to look for other causes. Have you run a scan for trouble codes? Does the truck start right up again?
    There are many reason for stalling, so you have to go at this step by step in a logical fashion. If it were my truck, after doing the scan, if nothing comes up, then I'd test the fuel pressure and see how that reads to spec.
    I'd also look for conspicuous vacuum leaks, like a loose or cracked hose somewhere.
Answers
  • cableman3cableman3 Member Posts: 2
    the motor WILL restart and stay running if you hold rpm’s up only shuts down AFTER warming up to temp does not over heat
    only when idling or stopping(foot off gas and braking) will it quit
    idle does not bounce up and down it stays steady then it drops revs up then off
