fault light
mruss2mruss2 Member Posts: 1
edited February 2018 in BMW
I recently purchased a 2010 bmw 328i coupe. I keep getting an alarm pop up every so often of a triangle with a circle around it and above it the word "brake". It goes out after awhile. Had the car checked couldent find anything that would cause it.
  • kyfdxkyfdx Moderator Posts: 271,472
    Is it possible that it's the warning that the ABS/traction control system is engaged? Does it happen when you are spinning tires, or taking a corner fairly fast?
    Poked around and found a pdf of the manual.
  • turrrrboturrrrbo Member Posts: 4
    Either traction control is faulty or you need new tires. Winter time...maybe roads are cold and icy?
