Can somebody help me pinpoint exact problem
behemoth666
Member Posts: 3
I have a 2004 Dodge grand Caravan SE 3.3 L reading code P0172 and P0301 strong smell of either gas or exhaust in the cabin also miss firing rough idle and sometimes stalling I know with the code reading it could be multi Multiple things can somebody help me pinpoint what exactly is wrong with it so I don’t misdiagnose it
Best Answers
OptionsMr_Shiftright Member Posts: 64,481Well the P0172 is probably caused by the misfire P0301. There's no way to tell you what the exact cause is--you have to test each possible cause. If you want me to guess with your money I'd say spark plugs and/or plug wires--especially if those haven't been changed in a long time.
You could possibly switch spark plug wires and see if the trouble code moves the other cylinder you switched.
Faulty spark plug or wire
Faulty coil (pack)
Faulty oxygen sensor(s)
Faulty fuel injector
Burned exhaust valve
Running out of fuel
Poor compression
1 -
Optionsbehemoth666 Member Posts: 3Mr_Shiftright said:Well the P0172 is probably caused by the misfire P0301. There's no way to tell you what the exact cause is--you have to test each possible cause. If you want me to guess with your money I'd say spark plugs and/or plug wires--especially if those haven't been changed in a long time. You could possibly switch spark plug wires and see if the trouble code moves the other cylinder you switched. Faulty spark plug or wire Faulty coil (pack) Faulty oxygen sensor(s) Faulty fuel injector Burned exhaust valve Running out of fuel Poor compression
replaced the old ones with autolite platinum spark plugs they’re good spark plugs at least I thought they were can’t be wires I replaced those as well and for no fuel I always keep her tank full. I just don’t want to go buy a bunch of parts and it not being one but the other and wasting money
0 -
Optionsuceegod Member Posts: 3You may be having a vacuum leak, try checking the air intake system - MAF, air filter & throttle body5
Answers
