Buick Rendezvous Noises and Sounds
The noise is a deep humming sound, no vibration. Starts at about 35mph and stops at 60 and when I am just applying steady pressure on the gas pedal. If I push the pedal or let off it the noise will stop.
Makes no difference what type of road surface.
Sometimes the noise will start right away and next time I might have to drive for 15/20 minutes.
I tried to record the sound before I take it to the dealer, but I pick up to much road noise.
Any suggestions?
Any suggestions?
From what I've read about wheel bearings that was my first thought, but shouldn't they make a noise all the time?
We've always done our own work on our vehicles, but these new ones are getting complicated and now you almost have to go to a garage for repairs.
On other surfaces, such as a freshly seal coated road, the road noise is just terrible.
When we first tested the vehicle, I have no memory of it being like this.
Does anyone else have this problem? I seriously need help with this. There is some type of fix to the rear floor that somone mentioned here, but the dealer near me says them haven't heard of it. Please help!
For the other sounds is it just road noise or wind buffeting because rear windows are down way more the front windows? Or is it a whine that changes with speed that could indicate rear wheel bearing issue?
http://www.lemonauto.com/complaints/gm/buick_rendezvous.htm
Hope this helps...
Any ideas?
Also I have just noticed a whining noise on the driver's side.
Any ideas on that one as well?
It has 69,000 mi
Thank you,
Charayne Reed
Don't you agree?
Charayne Reed
Good Luck
Bill :lemon:
I wanted to let you know that I had my serpertime? belt replaced, that made the noise that i thought could be a bearing. The VERY next day my change oil light came on, ya know it wasn't happening while I was ALREADY there, so brought it in (as u know when THE car talks u have to jump on it or else lol) and need my transmission fluid changed as well. With it being an 02 the pan and the entire 9 yards had to be done, had it been any other yr, only the fluid would've had to have been changed. Anyway since changing the trans. fluid, NOT one sound, the thing drives like it's BRAND new!! It was too funny as they had another Rendezvous, that had just come in, 08 and was still there. I asked if they were having trouble GIVING it away, hahaha!
I just hit 70,000, how many mi does urs have?
Bill
That would be the serpentine belt.
SUVs and Smart Shopper
Please sorry for my english cause I speak french.
I have a problem (I think it's problem, and maybe not very serious ) I have a noise on front differential , I asked many people (repair ) and they said that I need to change by another one.
Is it true? and is it (my important question) dangerous to drive this car now. If I drive my car under 70km/h the noise is here, but more than 70km/h the noise disappears. Please let me know..Now the very important question we have ticket from New york to Los Angeles 6-01-2012 and we want to go to to New York from Montreal by car and after one week we'll return back to Montreal Can I drive with this car and I'll repair after.
Please I need your help
Happy Holidays
I have a 2002 Rendezvous, currently when hitting 35 mph she sounds like she is on a ventilator, and it looks as if the tachometer is revving at that moment when it makes the noise the breathing stops when I let my foot off the gas! I have NO codes/engine light. I've taken her to a mechanic and they have no idea, no vacuum leaks either. 2 yrs ago I had a new head-gasket put in. 4 yrs ago I had a new transmission put in and my differential done. At this point I am at a loss and unfortunately bought her as an unknown lemon. We were thinking maybe the Torque converter, but truly unsure. Any thoughts? Please help.
You can still have codes stored in the TCM, or the TCM portion of the ECM. I'd certainly hook up a professional scan tool and look around.
Does the squeak go away if you press the brake pedal and hold it while slowing down from a higher speed?
It might be the pads themselves squeaking against the rotors, which I assume were machined or new ones put on.
It might be a backing plate that's behind the rotors to protect from splash and dirt somewhat that is rubbing against the wheel because the backing plate is bent or out-of-place.
If you're do it youself..., jack up each wheel and rotate to listen for the sound of something rubbing, whether it's the brake pads or a backing plate. If you can already tell from inside while driving that it's from a specific wheel, start with that one, of course.
If a garage did the work, go back and tell them you're getting a noise that they need to inspect. They should be happy to fix it.
Also it gives off this burning smell while using the heater.
Not sure about the "funny noise", as this can be related to so many things whirring around inside the engine bay.
You might see if you here the noise with the engine off while pressing the pedal, and if you do, get a friend to help you track it down.
Additional burning smells I've had are from a small coolant leak that hits a hot area around the exhaust and rubber tubing or wiring bundles near exhaust areas. These under the hood sources can be sucked in through the air intake that supplies the HVAC system.
You might try opening the hood after shutting the engine off when you smell this odor. I have even left the hood down and just sniffed around the open seams to see if I could smell the same odor from under the hood (on a day when there's no wind...).
Something to think about are does the smell happen with the AC on especially when set for cold temps. Even when the requested temp is for cold air, the heater core still gets up to full operating temperature: the air stream bypasses the hot core when asking for cool air or AC.
Possibility is the source might be inside the car. The heater core itself may have some sealer material that has aged in 13 years and is touching the heater core. This scent would not occur until the engine is up to full operating temperature which means the water going through the heater core would be hottest.
Without a definition of the scent that's more specific, it's hard to know where to look.
