Intense vibrations
infinity311infinity311 Member Posts: 1
edited April 2018 in Mazda
Okay, so I have a 2006 mazda mx5, 151,000 miles and the problem I've ran into is that I shifted fast and than heard a clunk under my seat. Engine light came on with a code for the knock sensor that unfortunately was intermittent. Replaced it and ever since it hasn't ran the same. Any ideas would be greatly appreciated!
Answers
  • Sounds like is the engine is what's running rough, and it's not a wheel or tire causing the vibration.
    that too-fast-shift may have caused timing belt or chain to skip over a gear tooth resulting in timing being way off. consider inspecting timing chain and timing gear for damage or looseness, and check and any pulleys/springs that keep it tight, make sure it's all in spec.
