Loud engine knock under load
I've tried just about everything at this point. I have a 2005 mitsubishi outlander that's at about 165,000. At the beginning of the year, it started developing a small knocking sound and it's gotten progressively worse to the point I don't feel comfortable driving it. It only happens when the engine is under load, usually going uphill. I used to think it was affected by the rpm's but I've since decided speed of the engine does not affect it. It's really quite loud and rhythmic. The only time it seems random is when I let off the gas a little going up hill. It sounds great at idle and I can rev it up to 3500 rpms in neutral without any problem whatsoever. The weirdest thing to me is that I don't feel like there's any loss of power. If I was completely deaf, I wouldn't suspect any sort of issue.
Here's what I've tried so far:
-Replaced timing belt, balancer belt, and pulleys
-Replaced VVT solenoid
-Cleaned out the EGR valve
-Replaced the fuel filter (though not sure if this would actually affect anything)
-readjusted the valve clearance
- changed oil
There was no change after each of these things
Other possibilities I suspect could be the issue:
-Bad knock sensor
-carbon build-up (Plan to try the seafoam cleaner)
-bad rod bearing
-blown head gasket
- Vacuum Leak
I'd appreciate any input as to what to attack next. Thanks!
- changed oil
-Bad knock sensor
-bad rod bearing
-blown head gasket
- Vacuum Leak
Do you mean like the click of valve lifters--a loud tapping?
Or do you mean a KNOCK, which is a sharp RAP you could easily hear from outside the car?
Does the noise increase and decrease with engine RPM?
What happens if you put it in gear and race the engine a bit (not too much) while your foot is on the brake (that is, putting the engine under load)?
When you say increase, I assume you mean volume. I don't think there is any change in volume with speed. The frequency of the noise definitely increases with engine speed. The sound only gets louder when I'm at low rpms going uphill. When the engine is under load.
I haven't tried racing the engine in gear with the brake on but I suspect a similar thing will happen that happens going uphill.
