2015 Nissan Rogue
I bought a 2015 Nissan Rogue SV last week. During the test drive for 5-10 minutes I was fine. I had a rental rogue for two weeks back in October and felt fine driving it. I drive 35 minutes one way to work. Driving it to work has caused lower back pain. the seats feel to firm and the bottom sides push on my sciatic nerve. Has anyone else had this problem? If so have you found a solution? Otherwise I love the car.
They are suppose to be zero gravity seats.
Answers
You may need to have an upholstery shop check it out with you sitting in it and then, if possible, make adjustments with more or less padding, and some shaping.
Or you might consider some kind of gel pad that raises you up a bit. That might work, as long as you don't slide around on it.
