Anything special about Civic Hybrid transmission fluid?
cellwhisperer
Member Posts: 2
Took my trusty 2003 Civic Hybrid to a Honda dealer for an oil change in our new retirement city. Didn't check Yelp first. Proposed $1800 repair. Ended up changing transmission fluid and now it's stuck in my driveway. Can't shift.
Answers
(Automatic Transmission Fluid). If it is not available, you may use a DEXRON III automatic
transmission fluid as a temporary replacement. However, continued use can affect shift quality. Have the transmission flushed and refilled with Honda ATF-Z1 as soon as it is convenient."
Honda ATF-Z1 is no longer manufactured and has been superseded by Honda ATF DW-1. DW-1 is backwards compatible with Z1. My original answer is correct (btw I had researched this for you before posting the first time).
