Front End problems
rodgert4rodgert4 Member Posts: 2
edited July 2018 in Chevrolet
when you grab one of the front wheels from front to back,play in front end , when this happens the center link rotates up and down, is this suppose to happen?
    There shouldn't be any up/down motion. You mean like a "kink"? Every joint (two outer, two inner connecting) should be tight with no play.
  • rodgert4rodgert4 Member Posts: 2
    Thanks Mr Shiftright! Went ahead and bought a new center link, and beefier idler arm (moog # k6187t). Hope this solves the problem. Former owner said he had replaced everything at least once on the front end Replaced the front pads about a week ago, when you apply the brakes, the brakes hang up left or right tapping brakes frees it up,when this happens pulls to left or right!
