What would cause my driver side power panel to stop only when it rains
                    Firs time on this site. I have a 2006 Trailblazer. When it rains, the power panel on the drivers door stops working. All of the other panels still work. It seems that after it dries, it works again. It does this every time it rains. I do not see and water around the plug.  Any suggestions would be appreciated.
            Best Answer
             Mr_Shiftright
                            Member Posts: 64,481
                    You might CHECK THIS OUT Mr_Shiftright
 Water intrusion seems a common problem on Trailblazers, and the module controlling your power panel might be located elsewhere under the dash. Also checking the fuse box for water intrusion would be a good idea.
 5
Answers
