Subaru Crew - Future Models
1282931333439
    Well, I think you need turbulence, and at paisan's "normal" speeds, I'm sure there's pleny of that! ;)
    -juice
    You mean not everyone drives a minimum of 10mph over the posted speed limit? :)
    -mike
    is what I'm talking about. Garry from SCOA seemed pretty certain it has to do with the windshield angle of the Forester. He thought that the angle caused the air turbulence to occur closer to the opening of the moonroof.
    Bob
    The Forester has a built in air deflector too. I
    tried holding it down, just to see what the effect
    would be. It's louder still.
    Bob
    Sounds like good food for future product designers to chew. Other markets did have a moonroof option right from the start, so I'm surprised it wasn't designed to be more quiet.
    Still, I wish I had that noise (and the bigger opening!).
    -juice
  • p0926p0926 Member Posts: 4,423
    Bob- The moonroof on my wife's Accord is uncomfortably noisy at hwy speeds. Same goes for previous cars I've owned. I just assumed that driving with the moonroof open was intended for the slower speeds associated with scenic rides in the countryside (35-45 mph). I'd say you're fortunate that your Explorer's is so quiet on the highway (55+ mph).
    -Frank P.
    I had an old '88 Accord LXi, before the Explorer. It too had a moonroof. I don't remember it being terribly noisy though.
    Mind you, my Explorer's moonroof is not silent. There is noise, just not nearly as much as comes from the Forester.
    Yeah, maybe I'm lucky.
    Bob
  • locke2clocke2c Member Posts: 5,038
    H6 fans will want to check this out. The new japanese-market WRX STi's six speed transmission apparently has 11 bolts just like the 4EAT used on the H6.
    There's hope for something other than a slushbox with the H6 yet.
    -Colin
    Where'd you get that link from? Any other goodies there?
    Bob
  • miksmimiksmi Member Posts: 1,246
    Good work, Colin! :D 6MT.. I like it!
    ..Mike
    ..Mike
    Slap that H6/6 speed in a nice and light GT and it'll FLY!
    -juice
  • potenzauspotenzaus Member Posts: 29
    Anybody knows the pros and cons of a turbo engine? Pros and cons for a normally aspirated engine?
    I've read somewhere that turbo engines need to be maintained more often than non-turbos. Is that true? How about the maintenance cost for a turbo compared with a non-turbo, are they the same?
    Would 6 cyl engines be a better choice than a 4 cyl turbos? How about the new WRX, would it have an annoying turbo lag as compared to a 6 cyl acceleration?
    Any arguments?
    You da MAN!
    Great links!
    WHAT! No power windows on the STi? Guess I'll have to pass.
    Bob
    Cons? You're supposed to give time for turbos to warm up and cool down. They usually require higher octane and shorter service intervals. There is also turbo lag since they depend on exhaust pressure to build up to produce power. You may need a beefier clutch or other mods if you're converting a N/A engine.
    Some twin turbos are sized differently so one kicks in early and the other later, to reduce lag.
    Pros? More power from a small engine. Gas mileage usually nearly the same as without.
    The alternative is supercharging. You can get better low end power, but the supercharger is a leach on the engine so gas mileage will suffer more. Peak power also may be less than what you could get with turbos.
    US customers prefer higher displacement engines, which explains the emphasis on the H6. They produce effortless (i.e. not having to rev), good low end torque without any lag.
    Trade offs include lower fuel mileage, more weight, and packaging constraints.
    There's no such thing as a free lunch. The H6 is better for relaxed driving, towing, hauling, and such. The WRX will be well suited for RallyX or other forms of racing (including street).
    My 2 cents'.
    -juice
    Think of the turbo as somewhat of a high-strung through bred, whereas the H-6 will be easier to live with.
    I used to own a Saab 9000 Turbo. You need to change the oil more frequently, what for the turbo to wind down before shutting down, it will probably have a peaky powerband.
    The H-6 many not be quite as quick (in its current state of tune), but will better for most non-enthusists.
    Bob
  • yellowbikedonyellowbikedon Member Posts: 228
    Stopped by my local dealer this afternoon for the weekly wash and was shown a white VDC which had just been prepped! A plate was put on the wagon and I was handed the keys for a 20 mile spin. Here are some of my initial impressions:
    *the VDC badging is done with taste both inside and out. It is really understated. You have to look twice.
    *the Momo steering wheel adds a nice touch to the interior. My feeling is that it's NOT gaudy.
    *the automatic temperature control is a delight and easy to use.
    *the eight way power seat is a great improvement and the lumbar support works well.
    *the car is silent, silent, silent. I couldn't believe how quiet it is.
    *The McIntosh audio system has to be heard to be believed. As a classical music fan, I was impressed with the depth and range of the speakers. WOW!
    *from a dead stop, the extra weight IS noticeable. While no rocket, performance is acceptable for most.
    *at approximately 3,000-3,500 RPM, the H6 comes into its "own." It moves!
    *as with other 2001 models, fit and build are up to our expectations, as expected.
    My L.L.Bean wagon is expected within two to three weeks. I am confident that the additional power from the H6 will put a hugh smile on my face.
    I am very much impressed with quality improvements found in the 2001 when compared to my '96 Outback. I remain convinced the extra dollars spent for the H6 rather than the LTD are worth the difference.
    I also noticed three Foresters with the new sport grill in my dealer's inventory. The grill seems to give the wagon a lower profile and while somewhat generic looking, really isn't that bad. The question is is it worth the $269 as shown on the sticker?
    I will be away for a few weeks when the L.L.Bean is delivered to my dealer. I will try to post impressions and reactions during December.
    Hey, if the H6 is now showing up in dealer inventory, does this mean postings no longer belong under "Future Models?"
    Don
  • rich97223rich97223 Member Posts: 3
    Hi all,
    I came across the WRX review on http://www.hoot-uk.com . This is 10/15/00 in US but the article is the lead article for 10/26/00 edition of hoot. After the 26th you will have to scroll down to view it
    rich@aadial.com
    10/15/00 should have been 10/25/00. Sorry
    rich@aadial.com
  • amishraamishra Member Posts: 367
    0-60 in 5.9 seconds? Gimme! gimme!
    What I found interesting was the direct comparison to the outgoing turbo model. It sounds like the new model will be a better "daily driver" than the old model.
    Bob
    VDC's are out aready? I thought it was mid-Nov? Time to call around to find one to test...
    Hey - until I own one, it's a "future model" to me! ;)
    That Forester grille ain't worth $269. Even if you like it, call Darlene and I'm sure you'll pay just over half that.
    WRX: holy cow, 5.9s to 60 and still 28mpg overall?! If you want burble, get a Borla!
    They seem to whine about it being too refined and less edgy, but face it, that's what it will need to succeed in the US. For each true enthusiast among us, there are 5 yuppies that will buy it because it'll be the flavor of the week.
    -juice
  • nematodenematode Member Posts: 448
    Where did you drive the VDC????? They dont get to Missouri dealers until to mid to late November or so I was told.
    If they are here already and I did not get a call I'm gonna get cranky.
    The VDC wagon was at Liberty Subaru in Libertyville, Il. If you drive on down, ask for Elmer Hansen and I'm sure he'll let you take a test spin! You'll enjoy it!
    Don
    Fitzgerald still doesn't show any on it's on-line inventory.
    -juice
    I'm sure you can come to Illinois for a test drive also! Didn't mean to exclude those not from the midwest!
    The only thing that struck a negative note in my "quick once over" was the tacky gold wheels on the H6. Other than that, the model is a sleeper!
    Don
  • aakersonaakerson Member Posts: 71
    Back to an earlier topic -- can Subaru expand its market position from what it is now to include high-performance and good handling etc.?
    Here's a least one yes vote -- from the UK mag. review of the new Impreza WRX. It refers to the Turbo as, " ... a formula so successful it has transformed the image of Subaru from a purveyor of sheepdog-carrying pick-ups into one of the most respected performance car manufacturers in the world."
    Watch the positioning of Subaru successfully EXPAND (not change) from its current functionality, quality, AWD uniqueness to include solid performance/handling and more upscale vehicles. And even the $30+ pricing, I believe, will not knock it out of the "great-value-for-the-dollar" category.
    Another prediction -- as a big portion of the current SUV owners (the ON-roaders) start trading in their behmoths, they're going to be thinking that SUV was too expensive, it was boring to drive, it got 18 inches to a gallon of increasingly expensive gas -- but it was great in snow and rain. Add to that the fact they're used to paying those godawful prices for an SUV, and you have an interesting set-up for what they'll buy next: Volvo, Audi, etc. And -- for a lot less money, Subaru.
    It's going to take some real clever marketing on Subaru's part, admittedly, because they're a niche player with niche budgets. But they're smart and have outstanding products.
    Two last comments: Subaru ... don't forget the roots and bedrock of your market position. Second ... get the WRX into the States ASAP. Soon as you do, my current Acura TL will be sitting on the front row of Webster Groves Subaru, St. Louis.
    Still no vehicle sightings yet.
    Bob
  • bluesubiebluesubie Member Posts: 3,497
    I hope you're right about the SUV craze winding down. I don't know though. It's already gone on a lot longer than people thought. And I hope this sport compact car boom that's been happening over the years remains strong and the cars don't die out like they did in the past.
    Dennis
    Don: is the gold color any different than the Outback Limited's?
    Those are pretty subtle. Chrysler, for example, uses a very gaudy gold that looks much tackier.
    Alan: you make several good points. The key word is "expand", as in I'm sure they'll not abandon the niche they've been so successful with.
    Brochure sightings, eh? Didn't you manage one back at the New York Auto Show? ;) Have they changed any?
    Future booms will come in smaller niches. I think crossovers will be big, like the STX. Coupes ought to make a come back as boomers realize they don't need 17 acres of interior room, too. The next SVX could have perfect timing.
    They should hurry up the 3rd row seat big SUW, though, 'cause that boom is happening NOW!
    -juice
    First signs of a softening SUV market -- Grand Cherokee sales are slowing, supposedly in part because it just isn't car-like enough (probably also because of the price). Meanwhile the finance entities are taking a beating on SUV leases now ending because the actual values of the turned-in SUVs are a thousand or more below what the lease payments had been set for. Also, I think I saw a rebate offer recently on the barn-sized windshield of an Excursion. 'Course I know the sales are still strong and the new Explorer, Highlander, Saturn SUVs are on the way.
    GJC's problem is poor quality. Rebates haven't helped to save it. It's down in an up market, which is real bad.
    -juice
    The gold on the H6 rims seems to be the same color as the LTD, however, there seems to be so much more surface with the new design.
    Don
  • kate5000kate5000 Member Posts: 1,271
    I've heard that many people were turned off by new styling. Quality has actually improved, sort off, but since SUV are mostly bought for "image", styling plays a big role for SUV.
    Gotcha, Don.
    Kate: Consumer Reports' reliability numbers for the new Jeep were the worst in recent memory.
    They had noisy axles, and even dealers admitted they permanently lost lots of customers because of this.
    I agree on the styling - someone said it looks like the old one "blown up" with a bit more air.
    -juice
    Just was comparing the new H-6 brochure with the regular Outback brochure. The new H-6 gets the same highway epa mileage rating as the H-4, @ 27 mpg. The city rating is 2 mpg less, @ 20 mpg.
    Bob
    for restyled JGC I mean...
    has been pushed back to 2006, from 2004 because Chrysler is losing money. There will be "update" of the current model for 2004 though. The JGC is going to look very "old" with its live axles, very shortly. The next generation model, originally scheduled for 2004 (now 2006), will have IFS/IRS.
    Same with the next Wrangler, and the about-to-be-released 2002 Cherokee. This new Cherokee may not be called a "Cherokee," however. The latest rumor is that it will be called the Jeep Freedom.
    In addition, the hoped for 300 Hemi convertible and the full-size Dodge SUV have just been axed for the same reason.
    The folks over at Mopar are fighting mad over these just announced vehicle cuts! So much for Chrysler and Mercedes synergy.
    Bob
  • alingaling Member Posts: 598
    According to an off-road guru on our M-class mailing list (which has and is working for DCX as a consultant), the next generation JGC was supposed to have an IFS, but still a live rear axle. Not sure if this is still going to work out for 2004. Since the 2004 JGC is still going to be on the same platform, I guess we can still expect less than stellar IIHS offset crash test results.
    Funny thing is that although Chrysler is losing money, MB has been gaining sales by leaps and bounds! I just hope they don't expand too quickly, or the exclusivity of the brand name could be diminished. I remember just a few years ago when there would be only 1 or 2 MBzs at the mall parking lot other than my own. Nowadays, it is not uncommon to find 4 or 5 (or more) of them.
    BTW, the next generation Range Rover will be based on the same platform as the BMW X5 and will have 4 wheel independent suspension (big surprise to me).
    Drew/aling
    Townhall Community Leader/Vans Conference
    WOW! 20/27 is remarkable! Are you sure those are the final numbers?
    Think about it, that crushes the XC's 18/22 and 4Motion's 17/24 EPA ratings, big time!
    I had guessed 20/25, and Car & Driver quoted 19/24, just to give you an idea.
    Go Subaru!
    That's a shame about the Hemi C. One of the few Chryslers I found interesting.
    -juice
    That's what's printed in the brochure.
    Bob
    I was aware of the Range Rover going independent all around. I was also under the impression that the next GC was going in that direction too.
    Regarding the Jeeps (all of them): there have been all sorts of rumors as to what suspension set ups they would receive. From what info I've been able to gather, my best guess is that they're all going fully independent. The Cherokee (Freedom?) will be shown this year at the Detroit Auto Show, and go on sale either next spring or summer. The Wrangler will follow suit in about a year after the Cherokee/Freedom.
    I could be wrong though.
    Bob
    In NYC movie set a few months ago. It pulled out in front of me and I was like "wow, that isn't a real car" It reminds me of the X-Terra, kinda cheapo pseudo tough SUV thing.
    -mike
    Just as "Blue Oval News" is a great source for Ford info, this "Buzz" site is the site to follow for Chrysler info:
    Bob
    http://www.car-truck.com/chryed/buzz.htm
  • armac13armac13 Member Posts: 1,129
    You obviously have not spent much time in Richmond lately. I swear that somedays it seems that every third or fourth car I see is an M-class! By far the most common SUV.
    Ross
    No, I wasn't referring to Richmond (haven't been there for 2 weeks). Yep, I know that there are lots of MLs there. I live in Coquitlam and there are (fortunately?) less MLs here; more RX300s in fact, where I live.
    Drew/aling
    requires 95 RON gas (premium). I guess that will the case with H-6s here in the States too.
    Bob
  • grahampetersgrahampeters Member Posts: 1,786
    I have found that my 99 OB runs markedly better on higher octane fuel. Run with normal Unleaded, it is fine but behavious under backing throttle when on a long trip where computer has leaned out the mixture, becomes very jerky. I suspect the H6 just accentuates this behaviour.
    Cheers
    Graham
    No offense Drew but I always get a kick out of people who buy MBs for the perceived "exclusivity". They're used for taxis in Germany for heavens sake!!!
    -Frank P.
  • lucien2lucien2 Member Posts: 2,984
    they're also offered with manual windows and cassette players, which goes a long way toward affordability. You get the build quality and safety, without the baubles and glitz
