Need instructions for removing and replacing manual window handle
1992Jimmy1992Jimmy Member Posts: 5
edited August 2018 in GMC
The driver's window handle is free-spinning. I hope the spindle isn't the problem. I've found online instructions for removing the handle with the special tool but none for replacing the handle.
  • thecardoc3thecardoc3 Member Posts: 5,858
    It's just a "U" shaped clip and the special tool just pushes the clip out of the groove in the handle. To install the handle you just push it on and the clip grabs the shaft from the window regulator.
    edited August 2018
    About $6 bucks
