2010 saturn outlook
Chuckster2018Chuckster2018 Member Posts: 6
edited August 2018 in Saturn
Low beam lights are dim at night maybe 25 to 50 feet no recalls on it ...so wher do I start ...high beams are great and very bright thanks
Answers
    You'll probably need a wiring diagram and look for where the low beam circuit is grounded. Might be a poor ground, if BOTH headlights are dim. You could also check the fuse box for corrosion at that fuse.
  • Chuckster2018Chuckster2018 Member Posts: 6
    Yes both head lights are dim but high beam are wonderful
    Just to get it out of MY head...it's not a headlight aiming issue?
    Yes both low beams are weak but the high beams are great
    I don't believe so but I could have that looked into
    And no recalls either I did look that up ...ugh
  • thecardoc3thecardoc3 Member Posts: 5,860
    First question, does your car have HID (high intensity discharge) lamps? Second question, do you have a volt/ohm meter?
    I have a ohm meter and not sure about the HID sorry this
