Parasitic power drain
I've recently developed a power drain coming from my power door lock circuit in my 97 dodge Dakota. Disconnected the switches, but still have the drain. If I pull the fuse it stops but then I have issues with the factory alarm.
Answers
You should also have a wiring diagram so you know what's on that circuit for that fuse and what's not on it.
Tracking down parasitic draws can be tedious. You might try a "wiggle test" at the harness leaving the fuse box to see if that changes any readings.
