Wet Emergency brake switch
my daughter bought a 2010 acadia about 2 years ago , recently the emergency brake light and the chime comes on when she is driving even though the brake is not set .
i looked at the switch and noticed a significant ammount of moisture , i sprayed the switch with 90% IPO to dry it out and it resolved the issue for now !
i read some posts talking about clogged drain tubes or pipes that can cause this issue but my daughters car does not have a sunroof , anyone had this problem before and know how to fix it ? i did not notice the floorboard being wet
So someone should remove the cowl and look inside to see if this is the case.
