Porsche Boxster Electrical Problems
So I'm a new Boxster owner (all of 2 months, 2007 model) and yes it drives wonderfully. But recently I left the lights on (my other cars headlights automatically shut off) and fully drained my battery. Well, what an experience. After putting my key in the ignition and realizing that the battery was dead, I found that I could not get the key out! I read the manual and it clearly states that if your battery is dead, do not put your key in the ignition as you will not be able to get it out. Q. When do you learn about a dead battery. A. After you try starting your car...WITH THE KEY IN THE IGNITION.
Anyhow, I also learned that both trunks can not be opened with a dead battery ... (this isn't completely true as the manual shows you how to connect positive terminal to fuse A and negative to door latch... it doesn't work and this is confirmed by the Porsche Road Assist guy.)
Anyhow, car gets towed to the dealer and the dealer says that if I need a new battery (after 2 months of use) it will be $330. I can afford the $330 but holy smokes that is crazy. I suggested that they put in a Canadian Tire battery for $100 as it comes with a 6 year warranty.
Welcome to the world of Porsche!
I did find a way to wire the boxters on www.whiteson.org/boxster/mods/drl/
but I would like to find out if there is a better way.
Scott
A dealer had given me 1014 and the real code was 0985. Figure that out?
thanks.
Within the last six month I replaced the battery but now that I haven't driven the car in over 10 days, the new battery is also dead.
Something must be draining the battery although I can't find anything further to turn off. Any suggestions or ideas??? Thanks,
http://www.amazon.com/Schumacher-SEM-1562A-Speed-Charge-Maintainer/dp/B0009IBJAS- /ref=sr_1_14?s=automotive&ie=UTF8&qid=1273114169&sr=1-14
:mad:
Thanks in anticipation of finding some advice.
I changes the battery in my 2003 boxster S to a Super Start® Extreme - Battery (Part # 48EXTJ) from O'Reilly.
There is some power getting to the car since the cigarette lighter lights up but nothing else. There is a whining noise coming from the front of the car when the battery is connected. The guy is the shop said this was charged, and it is supposed to be correct based their part finder.
Does this just need charged, or is the something else that could be wrong. Looking for other things to check out.
Any help appreciated
Have you checked your alternator?
I've had a brand new battery fitted in my Porsche Boxster 3.2 S year 2000 as the previous battery kept going dead, the radio would stop working and the fan. I ran the car and the same problem happened. Radio went off. Fan went off. I stopped turned off ignition and tried to start the car again. Nothing. No engine turn-over. All lights on. It was a very good quality new battery that was fitted. Something is draining the battery. Does anyone know what this problem is, please? I bought a trickle charger today and have connected it. I couldn't leave the alarms off as the door lights were on and I've had to close the front bonnet with the wire in it otherwise the light in there would not go off...... I would be so pleased to hear from anyone else that has had the same problem as it's so disappointing not being able to start your car up when you need it most
Nicola
How old is this battery? When "checking" it, who did that and how did they do it? The battery must be fully charged first, and then load-tested. Any battery more than say 7-8 years old would be questionable.
