Hatch Window Fails Intermittently, Tied to Toggling Door Locks!
I was driving on the interstate and my door locks began toggling on their own - and while that happened, my back hatch window lowered on its own and was locked in the down position. After a time, the window started working again, but then would fail again.
This has now happened on several occasions.
I also believe that the key locks are not working, but the keyless entry is working ok.
Bracing for cost shock at Toyota Service. Any ideas?
Another common cause is a break in the wiring harness as it threads between the body and the door.
