99 Jeep won’t start
I have 99 Jeep Grand Cherokee 4.0l in-line 6 when I go to start it enerything comes on as normal but I go to start it i only get one click from the starter and that’s it won’t turn over, I’ve replaced the starter the solenoid and the battery and I’ve got the same results one click then nothing. I’ve tried to jump the battery even though it’s new still nothing and I tried to jump the starter and still nothing. Please let me know if you have the answer to this thank you
Then as long as it turns, grab a volt meter and connect it from the battery negative post to the engine block and try to start the engine, record and post what the meter displayed. It should be less than .8v cranking, but if there is a bad ground connection you will see much higher.
Do the same with the battery positive cable, from the positive battery post to the battery cable connection at the starter. Cranking it should be less than 1.5v, if there is a bad connection then you will measure much higher.
