Lifting 3' 08 ford explorer xlt
Reyazteka3Reyazteka3 Member Posts: 8
edited February 2019 in Ford
How can I lift my explorer 08 3' or 1,75' all around whit out spending much.
Best Answer
    Answer ✓
    If you don't want to get into complicated suspension changes, you should probably stay at 2.5" or less, from all I've read on the subject. My truck is lifted 2", but I didn't do the work, and it seems to handle just fine the way it is. No matter if the lift is only 2" or 2.5", you should at least check your wheel alignment specs. If you go 2.75", you might consult with an expert about getting longer shocks absorbers at the very least. Once you hit 3", then big bucks start to roll.
Answers
  • thecardoc3thecardoc3 Member Posts: 5,863
    Most likely, "Incorrectly".
    Here's a good article on what to do and what NOT to do.
    There's no easy answer here. You have to match your budget to your needs, and you need to have a plan about what you are going to do with the vehicle after you lift it.
  • Reyazteka3Reyazteka3 Member Posts: 8
    My budge is around 300$ I'm planning on just lifting it enought so that the 12 inches of snow we get dont pille up under my car I want clearance and some all terrain tires but do t know what way to go 2.75' space and stock struts or do I need upper control arm and ball joint
