A Mechanic's Life - Tales From Under the Hood
1168169171173174
  • Mr_ShiftrightMr_Shiftright Sonoma, CaliforniaPosts: 64,490
    My friends at a local repair shop told me about a new hire. He seemed knowledgeable but then one day, about 4 days into his first week, the boss assigned him a certain job. Each mechanic gets a color code on the appointment sheet for that week---blue jobs, red jobs, yellow jobs, and they try to rotate the codes around so nobody gets stuck with one type of work. Well, the new hire looks at the job and says "Oh, I don't want to do that one".
    Goodbye.
  • isellhondasisellhondas Issaquah WashingtonPosts: 20,225
    You've got to take the bad with the good! Not every job is a "gravy" job. Some jobs are so miserable it's near impossible to make any money. The dealers usually get stuck with those jobs. Indy Shops can decline certain jobs but the dealership has to take them. Rat damage and burn jobs are the worst!
    The point is that the "boss" decides, right? The repair shop is a team, and the team works together to solve problems.
  • thecardoc3thecardoc3 Posts: 5,126
    Like every story, there is more to it. Exactly why did the tech not want that job? How many times have we seen a tech get badmouthed because he/she took on something that they in the end turned out to be not ready to handle?
    If a job is quoted out as a loser, then that is managements failure and no the tech shouldn't have to lose on it if management doesn't know what they are doing.
    edited February 5
    I don't think a good shop takes "loser" jobs in the first place.
    It's one thing to refuse a job because it's above one's level of competence, but another to refuse it just because it's unpleasant to do.
    How's this for a loser. Fiat's Multi-Air engine found in the Abarth and Dodge Dart. The Multi-Air actuators are failing and that results in the intake valves not opening which ends up causing a misfire. The assembly can be replaced but a special tool is required. http://www.freedomracing.com/10259b-engine-actuator-compressor-assembly-10259a.html?fbclid=IwAR2hKuqar6k8QOTZcW7n0fNAnkUv0T5TPDpNhaEMt3DUb2RDBNo8vUYCSnQ
    Shops and Techs are looking around for a more cost effective solution.
    Worth more than the car after a few years!
  • qbrozenqbrozen Posts: 26,305
    Looks like something you could make yourself for that kind of money
    '10 Equinox LS; '08 Charger R/T Daytona; '67 Coronet R/T; '14 Town&Country Limited; '18 BMW X2. 49-car history and counting!
    Certainly if you had a milling machine, seems like you could. Of course, you'd need to work on enough of these cars to justify the time. Basically these are throw-away cars, so I don't know that there's much profit in them.
    I've made more complicated tools, it does take a considerable amount of time when you make something totally by hand. There is a knock-off version of the tool that can be found on Ebay. You'll know you are looking at there since it's the one without pictures. Techs that got it have reported that unless they are very careful it doesn't work correctly and they end up breaking the assembly.
    breaking the tool or breaking the car?
    The replacement part, the solenoid and valve actuator assembly.
  • henrynhenryn Houston, TXPosts: 2,575
    I would think that the average independent shop would simply give a "pass" to this type of work, sending it to the dealership. And at the dealership, the mechanic would probably not be expected to buy this equipment, this would have to be furnished by the shop itself?
    I'm sure someone will come along and correct me if I'm wrong.
    2018 Ford F150 XLT Crew Cab, 2016 Chrysler Town & Country Touring
    That's probably how it would pan out, yes. There are some makes that most Indy repair shops shy away from, but they would do things like brakes or front end I would expect.
    Things like owning these kinds of tools are a numbers game for any technician. If you are doing a given repair often enough and even in the dealership, depending on how many techs have to share essential tools, not to mention if one suddenly comes up missing it would be no surprise at all for a tech to own something like this.
    Independent shops are buying this tool to take care of their customers who own one of these cars. It's just part of the cost of being in business.
    We have a great Indy Shop where I live that simply will not work on European cars. They are usually booked out at least a week and according to the manager they simply don't want the headaches that these cars tend to bring nor do they want to invest in additional tools and equipment. I respect them for this.
    I got a call from a shop, a European specialist that had a 2014 Jetta that he put an engine in that was a cranks but would not start. The recent history was the owner was reporting excessive oil consumption and replacing the oil separator didn't fix it. Then it came back as a hard start, misfire, no power with the plugs all fouled.
    With the new "used" engine the vehicle failed to start and kept cranking when he let off the key. He had to turn the key to the off position to get he starter to stop cranking the engine. After swapping the original engines wiring harness to the replacement engine only to have the same result he decided to replace the PCM, so he got a used one. That made the cranking issue go away but the engine still failed to start. He wrestled with this for about a month until another shop told hem about me.
    I got there around 11:30 am this morning and by the time he got done telling me everything that he did, started working on it about 12:15 pm. By 1pm I was putting my tools away.
    The first thing that I did was pull codes from all pf the modules on the car. The most important code wasn't a surprise, P1570 immobilizer. There was nothing that I could do for that code with the used computer in the car, so I instructed him to reinstall the original, cranking complaint or not. That corrected the immobilizer issue. One down....
    The next step was to check the ignition timing against the relative compression. That test passed.
    Now it was time to install the pressure transducer and see exactly what was going on in cylinder.
    That told quite a story if you know what you are looking at, the exhaust camshaft is clearly out of time.
    Two Down....
    That above capture though showed very high compression as well as it wasn't reaching atmospheric pressure during the intake stroke, so we pulled the upstream O2 sensor and repeated the test.
    Yep, a restricted exhaust. That explains the original loss of power, the misfiring and fouling the plugs.
    Three's a charm.....
    BTW this guy has a shop that you could eat off of the floor. He has been a known master at European vehicles since I was in high school but hasn't attended training in who knows how long.
  • xwesxxwesx Fairbanks, AlaskaPosts: 13,208
    Wow! So, all of that work he did, and really none of it made a difference... at least not a difference that took them in the right direction. :(
    I wonder, did your visit serve to relieve them or add to their frustration? :D
    2014 Audi Q7 TDI, 2008 and 2013 Subaru Forester(s), 1969 Chevrolet C20 Pickup, 1969 Ford Econoline 100, 1976 Ford F250 Pickup
    edited February 10
    xwesx  I wonder, did your visit serve to relieve them or add to their frustration? :D
    Lol. Not sure. He's looking at either pulling the timing cover off and fixing the cam timing, or getting another used engine and installing it. OR, he could reinstall the original engine, and replace the catalyst and then see where he is at.
    So the used engine was a turkey?
    I wonder if the clogged exhaust is actually the problem or the symptom? What a mess!
    I forget, is this a GDI engine?
    edited February 10
    The restricted exhaust is one of the original problems. The used engine was damaged either on removal from the donor vehicle or during installation. It's a simple mistake to make, while attaching/removing the torque convertor from the flywheel, the engine was rotated backwards. That results in the tensioner not being able to keep the chain under tension so it jumps time with the camshaft ending up advanced. In this case it jumped about five teeth. Yes this is a TSFI, a turbocharged GDI engine.
  • guitarzanguitarzan OhioPosts: 817
    Does the cat show signs of overheating such as discoloration of the exterior? I'm thinking plain steel possibly not.
    Oh man...and I'm thinking in a lot of cases, the installer would have no way of knowing this had happened UNTIL the engine get's started!
    Didn't look at it, so really don't know. All I was focused on doing was giving him the answers to what was wrong so that he could get this thing fixed and get it gone.
    edited February 11
    Correct. It's way too much "unpaid" work to open one up and inspect stuff like that. As the person installing the engine you really only have the recyclers word on whether the engine ran and if they noticed any issues in what ever time they had it fired up. Used engines are a a roll of the dice, you can get a winner, or a big loser.
    It's a lot of work to install an engine in one of these. At least I was able to leave him with some choices. Instead of replacing the engine, he can fix the timing and he has to address the restricted exhaust. He was a bit amazed that something that had been driving him crazy for a month took less than an hour to figure out and get him back on track.
    Those early GDI engines had some nasty carbon problems, too.
    Carbon deposits are common in GDI engines with only a few designs that won't suffer like the others. Toyota's D 4S system is an example of one that won't have deposits form on the intake valves. That design uses both port fuel injectors and direct injectors so fuel and it's detergents are regularly sprayed at the backs of the intake valves. Both GM and Ford are bringing out similar designs.
    A slick solution but really, more complicated engineering to correct what should have been done in the first place. You'd think they would have anticipated this problem.
    I'm not an automotive engineer, or a mechanical engineer, but I suspect this problem (carbon deposits in GDI engines) was not that easy to predict or foresee. Yes, looking back with 20/20 hindsight it seems pretty obvious.
    And I would have expected them to run these engines at least one or two hundred thousand miles before committing to wide spread use. But those tests were most likely in the lab, or on the test track, and didn't duplicate real world conditions.
    Direct Injection does have real world benefits, including better power, better mileage, and lower pollution. And exactly how do you implement it without carbon deposits? The system described above by @thecardoc3 is fine, but is definitely going to add cost, complexity, and any time you add more moving parts you are going to reduce reliability.
    I don't see any really good one size fits all solution here.
    I don't see how they could NOT have predicted it, given that detergents have been added to gasoline for decades specifically to help eliminate carbon build-up. It's like saying "We had no idea that blocking off the water-softener in your plumbing system would cause your pipes to clog up".
  • roadburnerroadburner Posts: 12,323
    My MS3 had a GDI turbo and I never touched the valves for the 8 years and 158,000 miles I owned it. No problems whatsoever. I even made some third gear acceleration runs at around 150,000 miles and they were essentially identical to the times I measured when the car had less than 40,000 miles on it.
    We'll see what happens with the N55 and N20 motors that are in my newer sleds.
    Mine: 1995 318ti Club Sport; 2014 M235i; 2009 Cooper Clubman; 1999 Wrangler; 1996 Speed Triple Challenge Cup Replica Wife's: 2015 X1 xDrive28i Son's: 2009 328i
    Your good luck is probably due more to the software design than the engine design. BMWs and Audi were notorious for this carbon buildup problem on the backside of the valves.
    If anyone was caught off guard and had to react to the valve deposits,  it would have been the early adapters such as VW and Audi. One of the major contributing factors was the lack of specific fuel additives that are found in Top Tier fuels. Today lots of brands of fuel are approved for Top Tier but ten years ago that wasn't the case.
    Other factors that contributed to formation of valve deposits was PCV flow rates that were too high. Oil separation systems that allowed microscopic oil droplets to pass. Excessive use of variable valve timing which increased valve overlap under stratified modes, and EGR. All of these together combined to create the carbon build up on the valves. Engineering advances served to reduce the tendency and severity but no engine is truly considered immune although the dual injection systems are close.
    edited February 26
    The aftermarket solution to Chryslers secure gateway module systems.
    From Automotive News..
    https://www.autonews.com/fixed-ops-journal/other-industries-raid-dealerships-talented-shop-veterans?ite=131351&ito=1397&itq=a0ed7813-832c-4930-9a22-33fc5d5e5e85&itx[idio]=7887464
    New-vehicle dealers have heard numerous alarms in recent years that they face a shortage of experienced service technicians as baby boomers retire and fewer would-be techs
    enroll in training programs. The National Automobile Dealers Association calls technician retention the "hottest topic" of the dealership performance improvement programs
    it sponsors.
    The shortage could become even more acute. Technicians dissatisfied with their compensation or work environment are finding greener pastures in other fields, often for higher pay. Moreover, as auto technicians acquire skills to work on advanced driver-assist systems, electric vehicles and autonomous vehicles, they become even more valuable to other industries that also face a shortage of highly trained technicians. They are potential candidates for poaching by industries such as heavy equipment, heavy-duty diesel,
    railroads and aerospace.
    A survey of 35,000 dealership technicians by Carlisle & Co. found that one-third plan to leave their jobs within three years. The survey did not break out how many plan to retire, move to other auto-tech jobs or change industries. But Harry Hollenberg, a Carlisle partner, says dealerships will need to hire 20,000 to 25,000 technicians annually over the next few years to cope with the shortage, and defection from auto retail is a significant factor.
    "Therein lies the challenge for our industry," Tony Molla, vice president of the Automotive Service Association, told Fixed Ops Journal. "An individual trained at a high level on the electronic side becomes very attractive to other segments of our economy, such as aerospace and fleet operations. We are competing for the same
    level of talent with other, more complex industries."
    Dan Jentel worked as a technician for seven years at Marquardt of Barrington, a Buick-GMC dealership in suburban Chicago, rising to the journeyman level. Now, though, $50,000 worth of automotive tools and testing equipment sit idle in his garage. Instead, he maintains industrial machinery at a company that makes office supplies.
    The factors that drove Jentel from the dealership echo frequent complaints from technicians: weekly pay that varied based on the workload and whether he could beat the clock under the flat-rate system, shrinking labor times for warranty repairs that reduced his pay and uneven distribution of work assignments that penalized more experienced, skilled technicians such as him.
    Jentel says he would fight to finish tough jobs on tight schedules, while less experienced techicians were turning more hours on easier jobs.
    "I did a lot of engines, and [General Motors] would shorten the labor times," Jentel says. "You would ask for more time because you want to do the job right, andthey would tell you, 'There's nothing left for it. This is all GM will pay at this point.' It didn't matter if every bolt on the cradle broke, that's what you get."
    Daniel Marquardt, an owner of Jentel's former dealership, agrees that shorter labor times for warranty work are "making it more and more difficult to acquire and retain skilled technicians."
    "For the manufacturers to [use] factory labor-time studies to justify shorting technicians versus actual times is just wrong, and I think it's morally bankrupt," Marquardt says.
    Quest for respect
    Robert Atwood, a management instructor at NADA Dealer Academy, says that how service techs are treated and the amount of respect they receive is the No. 1 reason they stick with a dealership for the long term. Giving only tough jobs to the top mechanics breeds unhappiness, Atwood adds.
    "You have an A technician who's been with you for 25 years, and unfortunately he ends up with all the s--- work because we know that person can fix it," he says. "They don't feel as though they are treated fairly. You have to go to this A tech and say, 'Look, I'll throw you some gravy later on, but help me out and get this done.'
    If we can do that on a regular basis, I think it goes a long way."
    Community colleges and technical schools training auto techs find that some potential students are turned off by the low starting pay — generally minimum wage to about $13 per hour for lube techs.
    Ira Siegel, professor of automotive technology at Moraine Valley Community College in the Chicago suburb of Palos Hills, Ill., notes that dealership shops don't need as many master techs as they used to. Because more work now consists of routine maintenance and basic repairs that lower-level technicians can perform, he says, there are
    fewer opportunities to move up.
    "Some of these students get impatient, and rightfully so, and they move on to another field," Siegel says. "I can tell you about six or seven guys who are working for various railroads, and these are guys who left a good dealership. It's just that they weren't getting moved up as fast as they want to."
    Train transfer
    One of Siegel's former students, Alan Saiz, worked at a Chrysler-Dodge-Jeep-Ram dealership in suburban Chicago for two years under the Mopar Career Automotive Program while he earned an associate degree. His full-time job as a dealership mechanic paid $16 an hour. He stayed at the dealership for only two months before he left to work for BNSF Railway as a diesel locomotive mechanic — for $27 an hour.
    His former employer "was a good dealership to work at, and the environment was good," Saiz says. But he quickly discovered he wanted more than it offered. "It didn't seem like there were a lot of areas where I could progress or move up," he says. "You were going to be a mechanic, and that's about as far as it goes."
    Two years after he joined BNSF, he was a journeyman making $32 per hour. Now, at age 27, he works for GE Transportation in an office, helping Amtrak repair shops troubleshoot and fix locomotives by telephone and computer, without getting his hands dirty.
    Saiz credits the education and training he received in automotive tech for paving the way to a higher-paying job.
    "It gives you skills and an education that you will use forever," he says of his dealership experience. "But I could just tell that the dealership life was not what I wanted to do for the rest of my life."
    I posted a response to that one.
    How many more articles like this will have to be written before real changes are finally made? Service technicians have been telling "the experts" for decades that the (flat rate) system is broken and it's way past time that the entire trade compensation system gets an overhaul.
    One of Mr. Atwoods comments above shows just how out of touch the leadership is with the realities of a service technicians world. In the article he stated "They don't feel as though they are treated fairly. You have to go to this A tech and say, 'Look, I'll throw you some gravy later on, but help me out and get this done.' If we can do that on a regular basis, I think it goes a long way."
    He is right with the first part that techs don't feel like they are being treated fairly and then goes right into one of the classic mistakes that the service department makes with it's technicians. The idea that throwing some gravy work to the tech somehow makes up for failing to pay him/her correctly for the more difficult work is at the very least wrong and if I can steal a phrase from above "morally bankrupt" itself. Think for a minute how the techs feel when the gravy work that was supposed to "make up" the lost time fails to materialize in a timely fashion if it ever does at all.
    From Mr. Marquardt's quote "For the manufacturers to [use] factory labor-time studies to justify shorting technicians versus actual times is just wrong, and I think it's morally bankrupt," As I read that it reminded me about how long this has been going on. I left dealer life back in the eighties because of all of the things that were wrong back then and not only did they never get fixed it's gotten worse, much worse.
    It's been more than fifteen years since this technician's website was founded. http://www.flatratetech.com/ That website was founded out of desperation because of Ford labor time cuts. One of the hardest pills to swallow back then as techs battled with Ford over labor times was when someone at Ford stated (paraphrased) "The labor times are only designed for dealer compensation for the work that the service department performs and are not intended to set technician compensation. That is a separate agreement between the technicians and the dealer".
    Today there are numerous technician's Facebook groups and dealers (every repair shop) should start paying a lot more attention to what the techs are saying to each other. Techs often ask if they should change jobs or careers and the responses from the other technicians are rarely encouraging. When they ask about going to a particular dealer brand the first thing someone else says is how dishonest the labor times are. They talk about how many tasks they are assigned that often end up as unpaid labor (investigating noises or random failures and especially instances where no problem is found). They talk about charge backs because something they did started out as customer pay but then later on turned into a warranty repair. The point is, these are all good people who like fixing cars and who are members of most of these groups because they are sharing ideas and mutually helping each other's knowledge and skills grow and most of them can't find enough positive reasons to tell another tech that they should come onboard.
    edited March 5
    edited March 6
    Yes and no. The biggest issue is tooling and training. O.E. targets when required can be very expensive. VW is over $8000 for their targets to set up their systems. In many cases existing shops aren't big enough. Toyota requires a perfectly level space 10meters deep and fifteen meters across in front of the car with nothing at all in that training area. Some businesses are erecting a building just for doing this kind of work. The O.Es state that this should not be done outside because of the potential for uneven lighting causing the training routine to be inaccurate.
    As far as targets go, there are aftermarket solutions such as Autel which can allow a shop to buy targets for just the manufacturers that the shop chooses to support, or they can buy the whole Autel set as it currently stands for around $20,000. Meanwhile the SAE is getting involved and investigating setting standards just like they did with OBDII because right now they consider it the wild west with all of the different tools and routines that are required to complete a calibration and training event. (I did mention that in a previous post)
    One of the worst issues has to do with knowing what systems are on a given car. While some can make it pretty obvious, (GM with their RPO codes) others require the tech to navigate through the onboard controls as well as use a scan tool with specific software just for the ADAS systems.
    One thing is for certain, the variations on the systems isn't going to slow down for at least a decade so studying to try to keep up is going to demand a lot of technicians time on top of everything else that they have to deal with.
    So fantastic for this type of need is an endowment, which would be *easy* to achieve for either manufacturers or chain dealerships, that sets aside funds now in perpetuity. From these earnings, they can consistently invest in top-notch on-site training centers that will allow their techs the space, time, and expertise to be up-to-date. Doesn't solve the other (pay, etc.) issues, but at least removes the burden of this type of overhead, both from the perspective of capital investment and trainer/trainee pay at no cost to the shops and no (additional) cost to the consumer.
    The problem is, nobody seems to think this far ahead. :'(
    Where would the money for the endowment(s) come from?
    From the Cardoc Foundation of course. B)
    Are you going to start a "GoFundMe" page? :)
    Why not? Something like:
    "Little CarDoc has an empty drawer in his tool chest this morning. You can help....or you turn away..."
    Source listed in my original comment. Also noted, though, was that this takes vision, and most "leaders" lack that trait even moreso than the rank and file.
    Definitely not following you here. You want the dealer to invest a large chunk of money for no return on the investment? When it comes to servicing the vehicles its difficult to get them to pay for things that will make the store money.
    Dealer wants profit. Techs want more money. Where do you think all this $$$ is going to come from?
    The entire system is no good anymore.
    There is only one place that it can come from.
    That's me, right?
    Well, it depends on what you think of as a return. My suggestion is that they invest a large chunk of money on something that will return, and will do it tomorrow and over generations. A one-time investment that can do that? Yeah, it's worth it.
    Like I said, it takes vision to build something like that, and such a trait is something that most people lack. Even most of those what would want to put money behind something like a training center would prefer to just put the money into building the center rather than putting it into building a legacy of training. Most people just don't think that far in advance or that holistically. It is why we are where we are.
    It's moving too fast for most people to catch-up or keep up. Worse than that, it's getting so complicated that no one person (or the rare person) understands the entire system in the car.
    Perhaps everything will break up into specialties, like in aerospace. One person does avionics, one guidance, one engines, etc. etc.
