SAturn Vue 2003
Bub21285Bub21285 Member Posts: 3
edited March 2019 in Saturn
My question is that I have had break problems and I have replaced bootster , master cylinder, calipers Hoses put breaks on it and rotors And break paddle goes straight to floor I’m sure I have air somewhere I. Lines but I have bleed the break like I would any other time or vehicle Just need a push towards my finish line I hope thanks
Answers
  • Bub21285Bub21285 Member Posts: 3
    edited March 2019
    Was master cylinder properly bled on bench before installation? Are the brake calipers on correctly with the bleeder screw at the highest point to let air out? ARe you able to cycle the ABS pump with your Tech II to clear the air out of it?
    Because so many parts were replaced, there's no way to diagnose from a distance. Problem now could be in so many places...
