1996 honda passport has trouble starting when clutch is pushed in.If you try to drive it before the
When it’s cold and you go to start the car with the clutch pushed in if you leave the clutch pushed in it’s real rough idling and sometimes will bog down or just die. now soon as it turns over if you let the clutch out it’ll stay started until it warms up. If you try to drive it before the engine warms up it’ll just die soon as you push the clutch in! Any help would be awesome thank you
Answers
I'm thinking that maybe pushing the clutch in creates just enough drag on the engine to lower what is already a critically low idle speed.
So I was wondering if you all saw this response from a few days ago and considered just how hard it was to figure out the first time any of us ever encountered similar failures?
Do you know how to check the crankshaft end play? If the thrust bearing has worn it's possible that stepping on the clutch is pushing the crankshaft forward and away from the crankshaft position sensor causing the signal to drop out.
It does go to show that on old, high mileage cars, anything is possible and the weirdest things can happen.
I saw a similar symptom years ago---again on an old car. Know what it was? The clutch pedal was actually acting as a ground to the electrical system, so when you pushed the clutch in, you lost the engine-to-frame ground!
Not the first thing that pop's into your head, is it?
