Colorado seat belt problems
trucktroubles2011c
Member Posts: 3
What causes the intermittent seat belt on 2011 chevy colorado.Put a new battery in ,no light instability till a week later.Suggestions,can I change the drivers side seat belt buckle with one from the back seat?
Best Answers
OptionsMr_Shiftright Member Posts: 64,481More often than not, this is either a wiring or sensor issue in the seat belt receptacle or the wiring under the seat. A professional scan tool could probably isolate the problem, at least to a certain area of the circuit.
No way I'd mess with switching buckles. You'd be better off even buying a good used receptacle off eBay from a reputable vendor, or going to a Pick n Pull and getting one off a truck that obviously didn't have an airbag deployment.5 -
OptionsMr_Shiftright Member Posts: 64,481One that is capable of reading that type of code. Some of the simple "code readers" won't do it. So a more professional instrument.5
Answers
I would still encourage you to hook up a scan tool.
