08 Passat not starting
Yesterday my check engine light came on and it was too late to go have it plugged up to do diagnostics. I drove it this morning a few blocks and when I came back out it wouldn’t start. It tried to turn over the first time but now nothing. Lights, radio, etc work but nothing when I push the key in. It jerked a few times the other day also. This is the first non-Chevy car I’ve owned and have no clue where to start.
Answers
If you dont' have a charger, then get a jump start and see what happens.
If it cranks and cranks but doesn't start with a jump start, then squirt some starting fluid into the air intake while it is cranking, and see what happens. That will tell you if you have fuel delivery or injector pulse issue.
One of those two methods should get you started (if only briefly in the second case).
If it only runs on starter fluid, then the engine either isn't get sufficient fuel or the injectors aren't opening.
Retrieving the trouble code might be a big help before you get too involved, but you will at least need to charge up the battery to do that with most code readers.
