Oldsmobile Aurora Climate Control
in Oldsmobile
THE TEMP CONTROL FOR MY AC AND HEAT NO LONGER WORKS IT USED TO COME ON AND OFF NOW IT DOES NOT COME ON AT ALL. THE HEAT AND AC WORK BUT IT ONLY BLOWS ON MY FEET . I CAN CONTRAOL THE SPEED AND TEMP OFF OF THE AIR W/ THE CONTROLS ON MY STEERING WHEEL BUT THAT IS IT THE MAIN CONTROLS ON MY CENTER COUNSOL DONT WORK AT ALL. YOU CANT SEE THE INSIDE OR OUTSIDE TEMP AND NONE OF THE BUTTONS OR KNOBS WORK AT ALL. I HAVE ALSO NOTICED THAT THE AREA ABOVE THAT WHERE IT LIST THE DATE AND TIME I HAVE NO CONTROL OF THOSE BUTTONS EITHER WHILE THE TEMP CONTROL AREA IS OUT ?????? WHAT IS THIS I TRIED TO REPLACE THAT ENTIRE PIECE BUT THAT DID NOT WORK
1
car except for the a/c problems I have had.. Recently I have
had alot of problems with the Air conditioning Not coming on, no matter what buttons I push...if I tap the a/c clutch
it will come on momentarly then go off again. The system is
fully charged and I have replaced the relay and the pigtail
on the compressor and still nothing. Now that its getting
cold outside my heater won't blow hot air!! it will sometimes come on all by itslef and then goes back off!!
please anybody I need help bad!! its getting cold!!!!!
thanks alot~ Monty
to a battery and it worked fine..I did pull the modual
out and looked at it and it looked fine as far as not
melted etc..all the plug in's looked clean too. It's
like there isn't any power getting to or from the mudual.
would this thing keep the blower from coming on??
Hey any help is GREATLY appriceated!!!!!!!! Thanks monty
Quinn
quinn.christensen@intermountainmail.org
My sense is that the salvage unit I bought also has a problem, but because it runs intermittently, the problem has to be with the module / pigtail. Looking for confirmation before I buy a new module.
My money is on the blower control module.
The connector to the module can be the problem with corroded or poor connections causing heat due to resistance, and that heat distorts the plastic around it giving poor physical pressure on the contacts resulting in more heat and problems.
The blower motor commutator can wear and the brush that contacts it may stick. This usually causes the blower motor to not run on startup until the car hits a bump which vibrates the motor and the armature and commutator move a little and contact the brush or vice versa. Replace the blower motor. An empirical test for this is to tap the top of your shoe against the blower motor while key is on and motor is not turning when it should. BUT this also may vibrate the connection at the lead for the blower control module. So careful diagnosis is called for.
