warranty on oil change?
SubaruownerSubaruowner Member Posts: 3
edited May 2019 in Subaru
How important is it to have a warranty on an oil change? One mechanic said their warranty is 12,000 miles or 12 months, but there's no warranty on oil changes, because there are no parts. Thank you!
  • kyfdxkyfdx Moderator Posts: 275,219
    Oil changes are maintenance, not repairs. No warranty.
    You wouldn't get a warranty on a car wash, would you?
  • SubaruownerSubaruowner Member Posts: 3
    Thanks! I wasn't sure, as once a mechanic failed to replace a screw after doing an oil change, and another failed to tighten a part, resulting in an oil leak.
    Even without a "warranty", any mechanic will guarantee their work, and fix anything they broke. Otherwise, they won't be in business long.
    Thanks! It sounds like you wouldn't worry about not having a warranty on an oil change. With each of the prior experiences with oil changes, either I had to bring the car back to the original place, or it was diagnosed by another mechanic. Can I identify good mechanics by whether they warranty their oil changes?
    If you are having that much trouble with oil changes, take it to the dealer.
