I had a locksmith come out reprogram a key for a 2003 Jeep Grand Cherokee unfortunately after drivin
MissChrisMissChris Member Posts: 2
edited May 2019 in Jeep
What can I do now after having the key reprogram for the vehicle to be doing the same thing thank you
Answers
    What is the vehicle doing? Looks like you tried to type everything in the title and the character limit for titles cut off some information
  • MissChrisMissChris Member Posts: 2
    Oops,  it died after 2 miles driving,  guages went crazy,  then dead,  jeep shutdown.... It has the same problem I had b4 having locksmith reprogram my key.   Is it the PCM,  should it be replaced
  • thecardoc3thecardoc3 Member Posts: 5,861
    edited May 2019
    It needs to be diagnosed, which means follow a proper routine during the failure. FWIW the key can shut the vehicle down in the first couple of seconds immediately after start, or prevent the engine from starting but not after that. Once the car has run more than about five seconds the theft deterrent is blocked from disabling the vehicle.
