AWD vs 4WD: What's the Difference & Which to Choose? | Edmunds
Edmunds.com
What is the difference between all-wheel drive and four-wheel drive? Which is right for you in snow, ice or sand? Edmunds sorts out the confusing terminology, explains how AWD and 4WD work, and lays out the pros and cons. Here's handy information for buying your next car, truck or SUV.
AWD will certainly help, but most FWD-based systems won’t kick in the rear wheels, until the front wheels start spinning. Makes for a jerky pull, and not easy on the transfer case.
You really need a RWD-based vehicle for towing/pulling duty. Something like a Durango or Grand Cherokee.
But, is that something you want to drive the rest of the time?
If both systems provide proper traction to each wheel, why would 4wd be better than awd?
Disclaimer: I am an IT guy, I know very little about vehicles, I would like to , but I dont
4wd, in most trucks are really not true 4wd. They have a open differential that does not lock up. When slipping happens the power follows the path of least resistance, usually the back right tire and front left. Because of weight distribution this is usually enough. If the car has lockers, either electronic or manual then it will actually turn all four wheels. Usually even with a locking diff it will only lock the back wheels and still leave the front open.
First thanks for taking time to write this article. There is good general info in it which people new to the AWD/4WD discussion can benefit from.
Second, and this comment is really directed to Edmunds more generally than you specifically, this article is not very good for car buyers who simply want to know what AWD or 4WD systems work best. If Edmunds wishes to be a go to source for car buyers for AWD or 4WD buying choices, then they need to do better. How could they do better? By providing real traction comparison tests of different systems under a variety of slippery (simulated and / or live) conditions. For example, look at this test:
There are others like it. They are useful for potential buyers because they provide valuable information about which systems actually work better in practice rather than general theory or even specific AWD system theory.
The problem I find w/ tests like the one referenced above is that they are 1 - not comprehensive, 2- not current and 3 - don't cover enough different test conditions.
There are more options than ever now and manufactures are making claims about the improved and/or superior performance of their systems (e.g. Audi Quatro AWD or Honda iTVM AWD). But these are just claims. Potential buyers want to know which ones work best under different circumstances more than they want to know some theory about who different systems work.
Edumds seems to be a generally good car buyers resource but is terribly lacking in detailed real world comparisons for various AWD & 4WD systems. I believe that almost 50% of new cars sold are AWD or 4WD models. In areas where there is regular snow, I think it is almost 90%. This means there is a huge group of buyers wanting better info. Edmunds should address this.
Now some comments on specific AWD / 4WD systems because there is a lot of bad info in the comments below.
I have lived for 10 years in an area that gets regular snow of between a few inches and 2feet and occasionally 4feet. I travel 3 miles of dirt roads which include up and down grades of up to 15%. I have owned 4 subarus (2 foresters, 1 outback and 1 impreza) and a variety of Dodge Ram trucks, Toyota Tacomas and a few other including a Mercedes Unimog. My neighbors have all manner of AWD & 4WD vehicles. I am therefore fairly experienced in the practical performance of various AWD and 4WD systems. Here is a short summary of my experience.
1 - Mercedes 2 or 4 wheel locking system like on the G-series wagon is the best I have seen outside of ATV vehicles like the Mercedes Unimog. This is not surprising but also info only useful to those who wish to spend 100-200k on a vehicle.
2 - IMO the best overall traction for a reasonable purchase and ongoing total maintenance cost is Subaru. With good snow tires and the standard 8-9inches of ground clearance, the Forester and Outback and shockingly good with their symmetrical AWD. You probably wouldn't believe it if I told you how many times myself or my wife have driven by other stuck vehicles of all kinds in our subarus. This claim is backed up by the 2011 roller test which I referenced in the beginning of my post. Note that Subaru is one of the few AWD cars which can climb a roller ramp w/ 3 / 4 wheels slipping.
3 - The older Tacomas are really not great unless you chain the wheels. Dodge 2500 is similar. Even though both have locked front differentials, if either both front wheels or either back wheel slips, you aren't going anywhere.
4 - Audi is also very good but expensive to maintain. Few people in the area own them so the sample size is small. I have not owned a Honda AWD/4WD so don't have personal experience w/ them.
5 - Hondas in general are not great but I do not know much about the newer iTVM AWD. Honda claims significant improvements in AWD in the last 10 years. Honda would be IMO a good choice of performance and price if the AWD system worked decent now.
6 - Toyota in general are similar to Honda in that they have claimed improvements and I do not have experience w/ the newer systems. Toyota would also be a good performance / price choice IMO if the AWD worked reasonably well now.
6 - I have very little experience w/ modern Ford, Chrysler/Dodge or GM AWD models. I would assume that if their systems worked reasonably well, they would also be a good price performance choice.
In conclusion, there are a lot of AWD models made by Toyota, Honda, Ford, Chrysler and GM which may be good performance vs price choices if a buyer could be assured that the AWD systems work reasonably well. Toyota and Honda are legendary for reliability and the American manufactures have been steadily improving in reliability for the last 30 years. There are also many models in these lines which are quite comfortable. Subaru, in spite of it's outstanding AWD, is not the most comfortable line. Improving but still IMO not keeping up w/ the others.
Please, use your influence at Edmunds to encourage Edmunds to provide actual real world and lab simulated testing results for potential AWD buyers. Thanks,
-George.
