2010 Freightliner Sprinter 2500 won't crank
I have a 2010 Freightliner Sprinter that won't crank. (diesel 3.0) When I turn the key I get full dash lights but no response from the starter. Trying to jump start the vehicle has no effect.
This same problem happened once before, I had it towed to the Mercedes Dealership where they charged me $5000 for new intake manifolds - which I'm certain had nothing to do with the problem and could have been cleaned with a can of carb cleaner.
Any assistance for troubleshooting the problem would be appreciated.
Answers
Odd though, the diagram calls for a 25A fuse if diesel engine, which it is, 20A fuse if Gasoline, which I don't think is available. The slot was populated with a 20A fuse and replacing with a 20A fuse blew the fuse immediately on attempting to start the van. Replaced with a 25A fuse, seems to be doing fine now. I just want to know... why was the 20A fuse sufficient for the past two years and now suddenly not.
