Coexisting With Drivers: 10 Rules for Bicyclists
Edmunds.com
Since bicyclists share the road with cars, they need to exercise as much caution as drivers do. Here are 10 accident-prevention rules for bicyclists.
It make sense, as the more vulnerable of the two, that bikers need to be extra careful and at tentative - however - in no way does that limit or lower the responsibility of car drivers to treat bikers as equal on the road; to give us the space we rightly deserve and have legal right to. For example, it is the driver who is responsible to ensure that no bike is imminent behind when opening the door - and is responsible for any "dooring."
Small quibble with "You have the right to go through that intersection at a reasonable speed" (#9). I'm not sure exactly how to interpret that, but I would NOT interpret it to mean you have a right to split lanes and ride up beside stopped cars in order to keep your momentum. That too is incompatible with safe and legal riding, and I see no basis for that in law. In some states it may be legal to filter up on the right, but here in Maine it is "at the cyclist's own risk", an admission that it's not the safest thing to do. Actually, it's not safe at all. It should only be done with extreme caution and slow speed. I've never had any trouble following "the letter of the law" at intersections, meaning I take my place in line (at least if the light is red) and use the proper lane, even if it means I might to wait for the light to change with the rest of the traffic. Even on a wet road or in heavy traffic, I've never had to slow down beyond my comfortable cruising speed to take an intersection this way. (Nor had to push myself to "keep up with traffic", for that matter, as many assume is required.)
Everything else, fine. Another I would add is communication, communication, communication. The more positive communication, the better. Communicate your intention, your expectation, and your thanks. It's amazing how much more positive your traffic riding experience gets when you just communicate with the other drivers. Strive to make your positive communication outweigh your negative communication. (The occasional yell of annoyance gets the best of all of us sometimes, and sometimes rightly so, but balance it out.)
It's usually not. Most of the dooring incidents I'm aware of are a result of the person in the car not looking behind and throwing open the door without any regard for any oncoming traffic (car or bike). In most cases, the cyclist has no time to avoid a collision.
At least in CA (where I live), it's the responsibility of the person opening the door to ensure that it's safe to do so.
Just as when I ride my bicycle, cyclists should use a bicycle lane or a normal "car" lane and hand signals. If they want to use a cross walk, they should walk their bike like a pedestrian. Bikes shouldn't use crosswalks just as much as cars don't use crosswalks.
Hopefully more states will adopt progressive laws like this.
Allowing "California stops" for cars or replacing stop signs with yield signs (or removing signs at most neighborhood intersections entirely) would also help traffic move and save gas.
At the end of the day, the cyclist would end up second best in any collision with a vehicle. TheGeekyCyclist wrote an article about how cyclists should be aware of their surroundings, especially in urban areas https://www.thegeekycyclist.com/tips/cyclist-avoid-getting-hit/
You don’t need a license plate, because they aren’t doing anything illegal, even though you may find it rude and/or annoying.
