What is this?
Luther42Luther42 Member Posts: 3
edited October 2019 in Jaguar
This thing is hanging below my glove compartment. Does anyone know what it is? Looks like is is broken off of something else. Doesn't seem to affect anything.
  • kyfdxkyfdx Moderator Posts: 271,245
    Looks like the hood cable, though I'm not sure that would be on the passenger side, under the glove box.
  • Luther42Luther42 Member Posts: 3
    No. It's definitely not that.
    Looks like a zip tie, holding the cable to the plastic piece? Or, does that look more like a factory fastener?
    No, it's not a zip tie. It's a small cable that appears to be factory installed
    Hmmm... let me see if we can get some other eyeballs in here.
    @thecardoc3
    That is definitely a zip tie holding the cable to the handle. You bought this car used? Where does the cable go? Could be a backup to open something that normally open electrically, such as the trunk or gas door?
  • corvettecorvette Member Posts: 11,653
    I was about to say the same - some sort of soft-open mechanism for the glovebox. If it's not bothering you, no need to fix it.
  • MindyloumsMindyloums Member Posts: 1
    edited October 2020
    Is there a list of compatible iPods for 2015 XK? I found the phone list but not iPod list.
