What tools will I need to remove dr door panel to fix power window?
I have an '08 Chevy Trailblazer LT with the 4.2L L6. The driver's window won't raise and lower and we believe the window is out of the track. We can fix this but I want to make sure I have the right tools (a video would be super!) before we start. I'm new and all help is greatly appreciated.
Answers
Also, it's likely that your window regulator has failed, and not that the window is off track.
Here is a cheap trim tool kit on Amazon:
https://www.amazon.com/GLK-Panel-Install-Removal-Installer/dp/B07C1857QC/ref=asc_df_B07C1857QC/?tag=hyprod-20&linkCode=df0&hvadid=312174136943&hvpos=1o2&hvnetw=g&hvrand=9739611636788048129&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9014426&hvtargid=pla-633452732397&psc=1&tag=&ref=&adgrpid=63790029762&hvpone=&hvptwo=&hvadid=312174136943&hvpos=1o2&hvnetw=g&hvrand=9739611636788048129&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9014426&hvtargid=pla-633452732397
A cursory test to see if your door switch is activating the motor is that usually a slight noise can be heard when activating the motor with the switch with on other things off and the key ON.
And to concur with Kyfdx's post, based on most others I read about for various GM's, I'd suggest looking up somewhere to remanufacture your regulator or buy a replacement from Ebay or rockauto.com, etc., if it turns out to be the regulator.
Circuit diagrams? bbbind.com lets you sign up and then download free their tsbs and circuit diagrams and autozone.com used to allow one to sign up and see circuits.
