2013-'15 Dodge Dart Recalled Because Transmission May Unexpectedly Shift to Neutral
Edmunds.com
Edmunds.com
I'm happy to be rid of my 2014 Dodge Dart. Goodbye forever, Fiat.
if you had the Dual Clutch Transmission, the recall was worded all wrong for what it really is. The problem stems from the fact that the analog settings were set on the bench and not while operating the car and out of three modules tested, the best behavior was obtained when the TCM unit was not grounded to the car. I tested the car under hot and very cold temps and surprisingly enough, COLD as in 20 degree weather was a bit of problem but once the transmission and system warmed up, it ran well. This problem, did not throw a code but when the car was put into gear, it just jerked the car every time it grabbed and released the clutch but went no where. Had I not let it warm up, then it would have thrown a code.
The one issue that a dual clutch transmission in these lines of car has is really bad for its following fans is that after 20000 miles worth of clutch disk wear the TCM is dumb enough to throw an out of tolerance error or a K1 Clutch out of range OBDII code. What makes it worse is that the dealers see this as an opportunity to charge a big ticket item for this condition when in fact the hardware is still very usable and could run for another 20x5 k miles as those clutch disks should. I have developed a 3D printed tool and kit to allow me to get the car running in a matter of 2 hours or less, the printed gadget design cost me about 500 dollars, hardware added. For more information, email me at Saenz_Edgar@ yahoo.com. Due to spam, please title your email "Dual Clutch Transmission HELP needed!" I am sharing this with everyone, because I dealt with two dealers in Austin Texas, South Point and Nyle Maxwell and both showed the same greedy and dishonest behaviors, You would not believe it, if I told you in this forum, I will post the entire video showing what they did and how they acted.\
Anyway, if you bought it new or used, the Dodge line of cars are really cool, specially the Limited.
Yes, Dodge Quality could be improved but I see this every where now so I am choosing to defeat them at their own game, which I already have but I had to purchase Dealer tools to investigate.
My wife and I love this Dart and we are keeping it alive and will not sell it as we are always asked to sell it.
Any ideas why
