Traction Control problem with Toyota Sienna 2004 and up.
I so hope posting this will help someone. I have had a problem with my TRACTION CONTROL in My 2004 TOYOTA SIENNA for the last 3 years. Nobody was able to figure out the problem until recently.
Toyota, various mechanics could not fix this. Your traction control comes on when your driving around corners or going up hill. there are various situations that will engage this traction control light to come on once you start experiencing this problem. The whole car grabs the road when this light gets engaged. The VSC light can come on as well.
Have your mechanic check your Racking Pinion assembly and sway bar links. I cannot believe my car is fixed. EVERY BLOG you read with this problem there is no solution that has fixed it. There are suggestions but not a guarannteed fix. This should of been a recall from Toyota but it was not.
I so hope this information can help you. If you live in the San Francisco Bay area
